Results 1 to 10 of 12
Thread: Tonight we hit 80 Degrees!
    Brookline, MA USA
    Default Re: Tonight we hit 80 Degrees!
    After a cold, rainy spring, and lots of illness, our solar panels brought our pool from 61 degrees 3 or 4 days ago to 78, then 80 degrees this afternoon and early evening!
    We normally start swimming in early May and swim the whole month--the solar panels warm it up SO nicely. This is the first year in many that we weren't swimming before Memorial Day, but at least we made it today!
    My next door neighbors are just starting their gas heater--meanwhile the water is 68-70 and their part-penguin kids are in it, playing!
    But it's nice to have it open, running and SWIMMING!
    Congrats for a good start. I also started the pool dip on Memorial Day Weekend. Temp was brought up from 64 to 80 in a day. My solar cover saves lots of gas bills
    but the trade off is mess with leaves and more work for covering and uncovering.
    Can you please give more details about your solar panels? What fraction of your pool surface area are they? Where are they mounted? How's season opening and closing? Do you use the pool's pump or a dedicated
    pump? I think I can get a system at Costco for about $600. I wonder if it's worth it.
    Thanks in advance.
    This is my ticket for Heaven (when all's working..) :
    22k Gal gunite IGP
    38 SF DE filter, 1 HP Hayward Super Pump
    Raypak 350k BTU Natural Gas Heater and solar cover
    8 gal Liquidator with bleach
    Dolphin robotic cleaner
    Taylor k-2006 test kit
    Quote Originally Posted by Water_man View Post
    Thanks in advance.
    I use a unique system that's called FantaSea and is solely marketed by Poolsupplies.com/leisureliving.com. They are 2'x4' hollow panels you can walk on--they are my deck around my pool. I have 30 or 32 of them--not sure. They form a surface area equivalent to three 4'x20' solar panels--240 square feet. My pool surface is 16'x40' = 640 square feet.
    They are permanently mounted--you need a well-supported 2x4 under each long side--the whole 4'. The ends and the center don't need support. They connect to each other like a set of dominos. Any that spring leaks I have to replace, but since the whole pool is a FantaSea, they send me new ones free.
    I simply have a Tee off the main return to supply the panels. There's a valve that allows them to be off, on just a little, or full-on. With my pump on low-speed they can be full on, but not when it's on full speed. No need for an extra or different pump unless you plan on mounting them on a roof.
    The great thing about the roll-up panels is that if you plan for expansion, you can start your system with one or two panels and only expand if you find it's not adequate. I personally think 1/3 of your surface area is plenty for summer use, and you only need more if you want to SERIOUSLY extend your season...assuming you get enough sunshine. I've found the normal recommendation of 1/2 your surface is really over-kill.
    Again, my parents had a 13,000 gallon oval that only got 6 hours of direct sun a day. I added a 4'x20' and a 4'x10' (same as a 2'x20') and, even with only 6 hours of sun the pool went from 78 to 84/85 for the whole summer. That's 540 square feet of pool to 120 square feet of panel--23%, not even 1/4.
    So...See how you like one or two panels and plan for adding more if you need them. I THINK the panels (4x20) run about $200, but you'll need more for fittings and connections. A tee off the return with a valve to control the panels (in addition to the ones they provide) plus all the hosing and fittings to the panels may increase your cost by about $100...but don't hold me to it.
    I love those solar panels! We opened the pool this morning after a chilly night to 82 degrees. By the time I turned off the panels that water was 87/88 degrees! Wonderful!
  1. Starting the conversion tonight...
    By mariner09 in forum Chlorine Alternatives: UV, Ozone, Baquacil (PHMB), etc
    Last Post: 06-05-2007, 02:08 PM
  2. Tonight I add salt to my non SWG above ground pool
    By The Raddish in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-28-2006, 08:28 PM
  3. water temp already 90 degrees
    By ScottS in forum Pool Equipment & Operations
    Last Post: 05-26-2006, 07:33 PM
  4. Bought a 27" ag round tonight
    By pkzmf in forum Above-Ground Pool Construction & Repair
    Last Post: 05-06-2006, 01:04 PM
