Results 1 to 10 of 52
Thread: Starting off just like I left last season :(
    scootchu is offline Registered+ Thread Analyst scootchu 0
    Default Re: Starting off just like I left last season :(
    Okay this is getting ridiculous. The particles stopped precipitating to the pool bottom as yesterday I had a small pile that I sent to waste.
    Now the water is clean, but not crystal clear. It has that haze to it.
    I just tested the water this morning and my numbers are good.
    FC - 12ppm
    CC - 0
    PH - 7.4
    ALK - 80
    Cal - 40
    CYA - 45
    I have been maintaining a high Chlorine level for fear of letting it drop and the water getting out of control, but something just isn't right.
    It seems like ever since I have installed a new liner the clarity has suffered. I know it's a coincidence, but weird.
    My filter is running 12 hours a day and when I do backwash I get lot's of green and brown discharge. I must be missing something incredibly obvious.
    mbar's Avatar
    Ashland, PA
    I would try a skimmer sock. All of your numbers are good. I think it just will take a little longer to "polish" the water. My water was the same this year. We had so much pollen, and the skimmer sock would need to be changed a couple of times a day. It took quite a while for the water to get the "polished" look that we all love. The fact that your filter is still collecting green stuff, sounds to me like there is still pollen in the water that is being filtered out. Try a skimmer sock, or if you have a sand filter you can add a little DE to the filter (you can search for adding DE to a sand filter on this forum), this may help to get the rest of it out of the water.
    Northeast PA
    Wink Re: Starting off just like I left last season :(
    Quote Originally Posted by mbar View Post
    I have been using a stocking and I tried a coffee filter the other day. It worked, but I think it creates too much suction on the basket. I got them from work so nothing lost. I think today I will try a real skimmer sock and see what that does. I do know that the suction from just a stocking cracked and bent my basket. LOL
    I used to add DE to my sand, but I switched to a generic Zeobrite media and from what I have read I cannot add DE to that. It was like that with the old sand too, so nothing has really changed.
    When I get home from work I will see what kind of surprise I have today!
    Just an update. The water is very clear and has been since adding Polyquat 60. Things have been very easy to maintain. Now the Robo-Kleen died, but you know what I would rather have clear water.
    Thanks for the help!
    mbar's Avatar
    Ashland, PA
    Thanks for giving us an update, I'm glad your water is clear
    Northeast PA
