Results 1 to 10 of 12
Thread: I have never had this much trouble before!
    Western Pennsylvania
    Default Re: I have never had this much trouble before!
    TC 5.6
    FC 5.3
    TA 200
    CA 190
    pH 8.0
    Thanks, I feel pretty meaningless lately too dealing with this pool.
    Quote Originally Posted by seminolewind View Post
    TC 5.6
    FC 5.3
    TA 200
    CA 190
    pH 8.0
    "shock level" for CYA=30 is between 10 and 15, not 5.3. See the "Best Guess table"
    Your pH is too high. Get it down to the mid 7's before you add chlorine, THEN shock it to 10+ and keep it there. pH of 8 makes it very hard for your chlorine to work.
    What CarlD said!
    Thanks a lot. My pH today is reading 7.8- 8.0 still. Do I need to filter or recirculate?
    Aim for 7.2 to 7.5--your chlorine will be a lot more effective then. But you STILL need to shock up your chlorine to proper levels to kill the bio-matter.
    mbar's Avatar
    Ashland, PA
    You need to filter 24/7
    Northeast PA
  1. Is it just me? Or does anyone else have trouble?
    By keschete in forum In-Ground Pool Construction and Repair
    Last Post: 07-13-2011, 09:16 AM
  2. pump trouble
    By mohawk in forum Pool Equipment & Operations
    Last Post: 11-21-2009, 09:59 PM
  3. Trouble getting CC to zero.
    By huskerfan in forum Dealing with Algae & Slime
    Last Post: 05-11-2007, 05:09 PM
  4. How do I add CYA? Having trouble...
    By Aviendha in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-12-2006, 04:25 PM
