Results 11 to 18 of 18
Thread: algae
    hannadock Guest
    Smile Re: algae
    ok for the last 6 days I have been dumping the bleach in. No algae but my water is cloudy. I can see the deep in but very little. I have been cleaning, vacumning on waste. what next? thanks for the help
    hannadock Guest
    Default Re: algae
    ph 7.6
    alk 180
    cya 35
    tc 11.0
    Default Re: algae
    A couple of questions. How many times a day are you testing and dosing with bleach? Is your chlorine level dropping off low before you shock it back up again? When you dose with bleach in the evening, are you still losing a lot of the chlorine overnight? Do you know your calcium hardness reading? Also, how much run time is your pump getting? You should be running it 24/7 while trying to clear your water. If your algae bloom really is dead, it may take a few days to let your filter clear the dead algae.
    hannadock Guest
    Default Re: algae
    I test in the evening and shock in the evening 4.5 gallons. I run 24/7. I don't know my calcium hardness off hand. I didn't think that applied to vinyl liners.
    I running my cleaner 2 to 3 hours in the evening. I noticed the chlorine dropped off after missing a day. thanks for you help
  6. #16
    Default Re: algae
    Quote Originally Posted by hannadock View Post
    It only matters if Calcium levels are too high. If your Ca reading is something like 500 or 600, and your T/A is 150-200, you are going to get cloudy water. Even with more appropriate T/A levels you may get cloudiness.
    Calcium is totally unnecessary for maintaining the water in vinyl pools. What that means is when the Pool Store Guy tries to sell you calcium additives "because your calcium is low", you shouldn't waste your money.
    But that doesn't mean if it gets too high you cannot have problems.
    hannadock Guest
    Default Re: algae
    I will check and repost. thanks everyone for the help
  8. #18
    hannadock Guest
    Smile Re: algae
    ph 7.7
    alk 210
    cya 35
    tc 11.0
    hardness shows very little.
  1. Avoiding Algae / Removing Algae
    By PoolDoc in forum Dealing with Algae & Slime
    Last Post: 07-24-2011, 10:40 PM
  2. Cloudy water...then very small amount of algae...then algae bloom
    By Allan in forum Dealing with Algae & Slime
    Last Post: 07-12-2011, 10:49 PM
  3. Wanted: Mustard algae or suspected mustard algae
    Last Post: 08-30-2007, 09:40 PM
  4. Green algae? Mustard algae?
