Results 1 to 10 of 12
Thread: help with first results of the season, ps234
    Default Re: help with first results of the season, ps234
    the water was very cloudy to start but I've been shocking the pool and now its clear but not crystal clear. I was using pool shock rather than chlorine since its a little more convenient and I had some leftover from last year.
    the bleach calculator says I need about 7 gallons of bleach to reach 15ppm. I typically shock the pool once a week after heavy use or heavy rainfall, so thats a lot of bleach to keep on hand. I guess I've seen a split of opinion in these forums on whether one needs to shock regularly if the chlorine readings stay in acceptable range.
    Unless you have a CC reading over 0.5, you shouldn't need to shock. It isn't hard to keep your chlorine level between 3-6 if you just are diligent about testing and adding bleach. I very seldom have to shock my pool because I very consistenly maintain my chlorine levels.
    If your CC is less than .5 ppm you do NOT need to shock. Most people do NOT need to shock weekly. Remember, shock is a verb, not a noun. It a procedure, not a product.
