Results 1 to 8 of 8
Thread: Is it really a problem if CYA is too high
    slowtan is offline ** No working email address ** slowtan 0
    Houston, TX, USA.
    Default Re: Is it really a problem if CYA is too high
    well I may try one more 50% drain/re-fill because I am not a fan of running high chlorine levels. I don't like the smell or the fading clothes that come with high chlorine.
    Stephen
    Actually, with high cya levels, the higher chlorine levels are no more likely to fade things than the lower chlorine/lower cya levels are. And, one other thing. You shouldn't smell chlorine in your pool. If you do, it usually means you need more chlorine! Sounds crazy, I know, but usually when you smell chlorine it means you have a CC reading and need to shock your pool to get rid of it. A properly maintained pool should not have a noticeable chlorine smell.
