We need a picture.
The higher the resolution and more detailed the better. If you are not able to upload it to a location, I can provide one for you if need be.
I'm thinking this is not a standard gunite pool, and if it is, it's just been through so much that it doesn't resemble one anymore.
That's very telling. Sounds like this fiberglass type thing I've yet to wrap my head around, could be the cause of a majority of the problems, when talking water loss.Originally Posted by King Bud
Purposeful "expansion" type joints would only occur in a concrete pool and not a plastered gunite pool (maybe rarely).Originally Posted by King Bud
Is the pool "painted" that you can tell? That's a dead give away of "concrete construction", of some type. Or is the "bottom" (shallow end floor,drop off, and deep end), a white (possible not pure white) smooth substance?
Your idea for the landscaping drains sounds about right but remember there's also a large volume of water that is shed from that section of deck too. Getting at the water as it comes down your hill is good, but the water that falls onto the deck and then is shed back to that area can cause just as many problems behind the walls. Although it's probably the much lesser amount of water compared to the hill it could still be enough to cause problems.
Are these diagonal lines/cracks perfectly straight? If so the deck has dropped right at the point it was predicted it would happen after the pouring of the deck. This would have been a different kind of "expansion joint", a relief joint. It's a weakened indentation, cut, or "score" in the concrete put there to make any pressure that will eventually crack the deck occur in a uniform manner. Think of the sections of concrete side walk. Even though the lines in them might not extend all the way through the concrete that is where they will most likely crack when "heaving" happens. If they (the diaganol lines) are not perfectly straight then they probably left them out. Which is right were they are normally put (diagonally at the corners), and periodically in long stretches too.Originally Posted by KingBud
That's most likely not a problem with the return line. Rarely will water being pushed through a return line, pick up air from that line and dispense it into the pool. A return line is more likely to push the water out of any "leak" while running. Air at some point is being introduced into the loop and thus being fed into the pool. Air most likely can't be introduced into the system with out it being "sucked" in. So water leaking from your filters, pumps or other systems topside are probably not the source (believe it or not), those are places water is being "pushed" out. Valves, threaded fittings, loose clamps form the suction of the pump, on out, is probably the source of the bubbles.Originally Posted by King Bud
If you can see the bubbles in a your pump "chamber", try this: Get a watering can or garden hose that you can regulate. Start where the suction lines come up out of the ground and trickle (pour till the fitting has water all around it, and continue to do this) water on any fitting (elbow, coupling, bushing etc), and valve. See if the bubbles go away or are reduced as you trickle the water all around these "connections". What happens is, the constant flow of water effectively seals the air leak temporarily. It might be in several places, so it make take trickling water on two different ones. Work your way back to the where the suction lines ends up at the pump. Even this fitting might be the culprit. Or any lid, threaded plug or other thing in the pump body itself.
Like I said though at this point I think we need a picture. I still can't picture (no pun intended) this fiberglass type section your describing. I think I understand "where" it is, but why it's there and what its function is, I have no idea. Could it possibly be a section where the plaster/gunite/ or concrete has actually completely failed and dropped away?
If you need help figuring out how to get a picture here (on the forum), or to me, we can work it out. Emailing me is activated in this forum as well as several Instant Messenger services I use.
