Page 4 of 4 FirstFirst ... 2 3 4
Results 31 to 34 of 34
Thread: Weekend Baquacil Conversion
  1. #31
    mjones is offline ** No working email address ** mjones 0
    Mississippi
    Default Re: Weekend Baquacil Conversion
    what do you mean by "damage" my liner? Re: my low ph?
  2. #32
  3. #33
    duraleigh Guest
    mjones,
    You would do much better to start your own thread so you can get the help you need.
    You will not have too much luck testing with strips. post your test results from a drops-based kit and we can give you help.
    That "outdoor" Clorox you used is not wise....you are putting stuff in your pool that is not helping you....post for FC, CC, CH, pH, Alk, and CYA.
  4. #34
    does the sand in the filter need to be replaced when this is all said and done?
  1. Baquacil CDX to Chlorine conversion
    By gbwarrior in forum Chlorine Alternatives: UV, Ozone, Baquacil (PHMB), etc
    Last Post: 02-07-2012, 03:59 PM
  2. Baquacil Conversion
    By duckmka in forum Chlorine Alternatives: UV, Ozone, Baquacil (PHMB), etc
    Last Post: 04-20-2007, 09:26 PM
  3. New Sand after Baquacil Conversion
    By lizzie64 in forum Pool Equipment & Operations
    Last Post: 07-06-2006, 09:25 PM
  4. Baquacil Conversion Done, Now what
    By bcpoolowner in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-22-2006, 12:13 AM
