Results 1 to 10 of 12
Thread: Math/New Water Help
    elsie is offline Registered+ Thread Analyst elsie 0
    Default Re: Math/New Water Help
    Well, I finally got the pool (with the new liner/water) opened this past weekend, unusually late for me, but every weekend during the month of May it rained and I need the solid winter cover to be dry and totally clear of debris before I take it off. And I prefer weekends because I don't like looking at the mold and crud on the pool deck that's gathered under the cover during the long months covered so need a few hours to bleach-clean and pressure wash.
    Although the water is as clear as I've ever seen it, there were pools of algae scattered about on the bottom. Although I never shocked it while it was covered, I did periodically add bleach which probably explains why the water remained very clear, at least that's my guess. As a new liner was installed last September, I did not want to shock and close and have such a high chlorine level for the 8 months it was covered. This is the first time I've never shocked before covering. At the end of this season what I will do is shock and then let level drift down to 4 or 5 and then cover and check it and maintain it during the winter months much like what I did this past season but for the first time I may just add some polyquat.
    In any case, I shocked to 15 and held it there for 2 days and brushed the pool each day as well as vacuumed a couple of times a day and the algae has not returned. Unfortunately, I don't think as a solo person I can vacuum to waste, can I, without someone holding the vacuum hooked up to the skimmer port so it [the vacuum head] stays in the water and doesn't suck air as I can't do that and be at the multiport at the same time? So I suppose I should probably backwash the filter, but since we're scheduled to get up to an inch of rain tomorrow I thought I'd wait since I will have to waste water anyway.
    And now, interestingly, I no longer have the issue of low pH. Just like my old water, my pH creeps up (as a creature of habit I prefer this). I added 1-1/2 cups of acid the other day and my pH is now spot-on, at least for a week or two. Adding a little acid is a lot more economical than a box of borax every week! My TA is running even higher than during the winter at around 220, but with such crisp, clear water it's not a problem.
    On a full sunny day w/my CYA at 50 I lose about 3 ppm of CL. Yesterday was clouds & sun and as predicted, I lost 2 ppm. Since about a third of a gallon (or 5 cups plus a tad) brings the ppm up 1, dosing is quite easy. On full sunny days I'll just add a gallon and others less. I just read a thread about preserving more FC with more CYA and although I don't understand much of chemgeek's posts as it's way more scientific than my brain can master, I'm wondering if I should raise CYA (and commensurately raise FC) to lessen the amount of bleach I will use (I still have CYA left over from last year so no out-of-pocket there). As it stands now, I figure maintenance bleach alone will run me about $30-$35 every 4 weeks with WalMart bleach @ 1.54 a gallon (it's so much easier to handle than the 1.42 jugs which then I must also measure out in cups to dose when I can just eyeball it with the gallon jugs, plus the 1.42 WalMart jugs only save a few pennies) plus more for heavy rains or needing to shock. I don't get the long hours of full sun like alyad's pool -- maybe only about 4.5 hours at most. I do run my filter 24/7 because of all the trees.
    This brings me to a question I think I asked some years before but to which I don't believe anyone responded. If, for example, low pH can damage a liner, for those of us who live in the south and whose water doesn't freeze (in my case when the temps drop below 30 for a sustained number of hours I just run the pump), we absolutely *should* maintain good numbers throughout these long winter months? Why would we be so committed to them during the swimming season (e.g., in order to preserve the liner) but not the off-season? I remember adding many boxes of borax over the winter to keep my pH up and although I'd rather not, it seems to me the prudent thing to do. With a brand new liner one's state of mind is just a tad different.
    Janet, if you're reading this, the darker blue liner quickly grew on me. I'll try to find some time here at work in the next day or two and upload some pics to the Kodak website to share as I don't think I can upload jpg's here.
    FC 6
    CC 0
    pH 7.5
    TA 220
    CYA 50
    Thanks and happy swimming!!! (76 degrees and rising fast)
    Hi Elsie, it's good to see you back this season!! I'm glad you like the liner, and I'd LOVE to see pictures, since I'm probably going to have to replace mine by next summer......assuming the piece of duct tape I have covering a small hole above the waterline on my pool holds us through this swim season! We've been swimming now for a couple of weeks, so taking the pool out of commission at this point is not something I even want to consider if I don't have to.
    As far as your question on winter water maintenance...I do also maintain my water numbers "close" to normal during the winter, although with the water being cold, I don't see much variation from week to week. The only things I really stay concerned about are my Cl and pH. I usually lose some CYA over the winter due to dilution and backwashing (I normally keep mine at 80 during the summer, but it will drop to 40 or so over the winter) but otherwise my pH stays pretty stable and it's really a matter of keeping enough Cl in it to keep the algae gone (and I get as lazy as the next person sometimes--this winter it stayed crystal clear until late March or so, and it took a few days to clear that one up, but it's back to clear now! ) My pool "likes" the pH at 7.8 and will stay there as long as I leave it alone, so I do.......and it only takes a few weeks of trichlor in the feeder after we start swimming to bring it back down and to start bumping my CYA back up again. You are very right--a new liner makes you look at things through completely different glasses!
    Hi Janet!
    Thanks for the welcome! I just put together a slideshow of my place to share with you, friends back in my home state of Minnesota and anyone else on the forum who cares to view my pool and property. By the way, I live in Maylene, Alabama, about 35 miles south of Birmingham. As a bit of background (I know this is long, but one can choose how much to read or not read), I bought this property 7 years ago for $102k (and with the falling housing market probably isn't worth much more than that now despite improvements). I've done a lot to it: had metal roofs installed on house and outbuildings; had it sided and new windows and patio door installed; stained the pool concrete deck and patio with H&C stain (great economy-a few hundred bucks and it transformed that old gray porous concrete beautifully); put a colored stain on the back and front decks and built a third, smaller deck "back in the little woods;" had trees removed that were hanging over the roof (but I still have to go up there routinely as well as on the metal roofs of the pool house and shed to blow crud off); and did a fair amount to the inside of the house as well. I also had the diving board and ladders removed to make a "flat" pool since it's pretty much just me using the pool. It's an older pool and there's nothing fancy-schmancy about it, but it is pretty.
    There's both an upper driveway with attached garage as well as a lower driveway with a huge carport (which I never use but still maintain by blowing off perpetual "gifts" from the trees). As I so often tell friends back home, this property OWNS me -- it's continual work year-round, from restaining the decks every Spring and trimming hundreds of bushes to hauling and putting down new cypress or cedar mulch to leaf work that goes on, and on and on, pressure washing the pool deck and of course the regular maintenance which is always ongoing. I think you live in LA, don't you? Spring here with all the trees is a horrific mess; I blow those things that come from all the budding trees daily during April and May, sometimes hourly when I just can't stand seeing them all over the place. They get so deep you could shovel them almost, and this goes on week after week after week. The price one pays when surrounded by trees...
    Luckily for me, a microburst type of storm rolled through last August and destroyed the pump and tore the ancient, leaking liner and there was no out-of-pocket for replacements except for a new multiport I had installed to replace the old one which wasn't damaged but had been giving me some trouble. The liner guy also put in a brand new floor beneath the new liner and, at my request, got rid of that main drain which wasn't operative anyway (but which still made me nervous). He replaced the StaRight 1.5 hp pump with a Hayward 1 hp Superpump (or maybe it was from 2 hp to 1.5 hp, I don't recall for sure). That concerned me but he said it would do just as good a job (maybe I'll save a bit on electricity).
    The darker liner is a deeper blue when the sunlight's off it, but it still has a nice aqua sheen in bright sunlight; I was unable to commit to an even darker liner as I really did enjoy the lighter aqua, so picked something in the middle. The only thing I don't like is that close up you can see all the seams (in the deep end they're like darts on a blouse), but you really have to be right on top of the pool to see them. Unavoidable, I'm told (my old liner had no pattern left so the seams were rather invisible). And on the aerial shots (I took from the roof), it almost appears as if the deep end is a little bleached, but it's not of course, it's just the way the light affects it.
    Fortunately, I'm an unusually active and fit 54 year old (two of my dogs are seniors now and go on shorter daily walks, but I take Betty, the larger rescue girl I adopted a year ago, hiking in the hills behind my house virtually every day), and though sometimes I dream of a garden home with a postage-sized yard, I know I'd be bored within the first day! So as long as I can keep the property up I'll stay. I mean, where else could I have such a beautiful place for my money?
    The URL below *should* work as I just tried it by copying it into my browser, but if it doesn't we can PM and share e-mail addys and I can forward the Kodak photoshare e-mail (just let me know). This is the first time I've used Kodak photoshare in a couple of years and they've made some interesting changes - you can control the speed of the slide show and background color (the default of black is best), then just hit the play button. It starts off with a few Spring photos with the pool cover still on. Unfortunately the pics aren't full screen anymore and there's a bit of distortion in them but heck, it's free!
    http://www.kodakgallery.com/ShareLan..._photos_button
