Results 1 to 10 of 10
Thread: Test results and questions
    Default Re: Test results and questions
    I understand what you're saying, but if I run the Aquabot for 4-6 hours for three straight days and the bottom of the pool is still covered hours later it has to be algae, right?
    Anyway, yes my SWG was not getting my chlorine up over 5 so I dumped in a bunch of Clorox and now it's up to 10. Yes the chlorine is dropping overnight and I have .5 CC's which hasn't gone away (should be zero right?). So I am going to keep the SWG at 100%, run the pump 24/7, and add chlorine as needed to keep it up around 10 for several days. Is this safe to swim in?
    Also, when you ask about chlorine levels dropping overnight what you're really asking is if they are dropping when the pump isn't running and the SWG is off...is that correct?
    One last thing...I added about 3lbs of stabilizer because I was getting a zero reading. I think it's testing around 20 right now and I was targeting 50ish. How is having a low CYA reading, or none at all, affecting my pool right now as I battle this algae?
    Thanks everyone.
    Are the sides of your pool covered with this stuff you think is algae, or is it just the bottom? And how much chlorine are you losing overnight in ppm? My vote still is dirt, but I could be wrong. I can tell you that just because your Aquabot has been used that much, you can still have dirt settling in your pool, but if you really think it's algae, then the only way to get rid of it is to shock it and keep it shocked until it goes away. I just hate to see you waste that much chlorine if it's not really algae. Also, if you're going to shock it and maintain that shock, you need to do it with chlorine (bleach)--the SWG can't keep up with a maintained shock level and you're putting a real draw on the cell life. The SWG will be much better at maintaining a baseline chlorine level than it will maintaining shock level (which is 15 ppm, now that your CYA is 20,not 10--if you're only going to 10 ppm, you're not going to win the battle if it is algae).
    As far as your stabilizer goes, I don't know by which method you added it, but it can take several days for it to completely dissolve into your water, so I wouldn't add any more until you've waited a couple of days and re-tested for it. Having the lower CYA reading is better than having none at all--you do have to maintain a slightly higher shock level, but at least you're not losing it all to the sun. Most people with SWG keep it around 80 because it's supposed to optimize cell life, but while you're shocking with other forms of chlorine to clear the pool, I would keep it on the lower side for now.
    I appreciate your advice. No the "algae" is not on the sides of the pool, it settles on the bottom...kind of in clumps. If it's dirt then I have a bad filter right? I mean seriously, running the Aquabot 6 hours a day and vacuuming every 3 days really should get the dirt out. I'm sure it's something else.
    Algae grows on the pool sides, often before it grows on the bottom.
