Thread: Removing chlorine?
    Default Removing chlorine?
    Ok, first of all, as a pool owner I don't need to or want to neutralize the chlorine in my pool, but as a professional photographer who's photographing models underwater...i'd like to neutralize/vaporize the chlorine on the day of the shoot and then deal with bringing it back to normal, natural levels after the fact.
    I want to make it as comfortable as possible for someone to open their eyes underwater. And the chlorine seems to be the biggest culprit to eye inflammation.
    Here's some examples of what I'm doing....
    http://www.kashandsherry.com/?p=128
    Any suggestions on how to do this in the shortest and safest time frame possible?
    Thanks,
    Kash Johnson
    Carrollton, GA
    Kash....Carrollton, Ga
    21x42 vinyl Lagoon 36,000 gallons
    Hayward 1.5HP Superpump & sand filter
    Aquarite SWG---currently testing with Walmart strips
    Default Re: Removing chlorine?
    I've got the ph at 7.4...that was my target, but i read an article concerning iconic photographer, Howard Schatz's pool and he mentioned neutralizing chlorine before a shoot. I didn't know that was possible or necessary, but i thought i would try it.
    Kash
    There is a chlorine neutralizer, but I'd argue get your pool squeaky clean so there's not a HINT of CCs, and raise your pH to the 7.6-7.8 range--which is most comfortable.
    You also should consider adding salt so that the salinity mirrors that of tears.
    Chlorine neutralizer is available from pool supplies. It is often just a solution of thio (sodium thiosulfate) but might often contain some other sulfites in addition
