Re: no pressure on recirculate
Sure sounds like an air leak somewhere and that somewhere would be on the suction side, not the pressure side so concentrate on the suction side. It also sounds like a very tiny leak and that's all it takes. You can try smearing vaseline around the pipe joints as it is thick and if you have a hairline crack that should seal it. Then fix it when you find it. Don't leave the vaseline on O-rings or gaskets for any period of time. Vaseline is cheap and cleans off easily. Also, is yours an above or in-ground pool? Reason I ask is for access to the skimmer basket connection. Under a deck can be a dog.
