Thread: Old Concrete Pool - Post-restoration issue?
    May 2010
    Default Old Concrete Pool - Post-restoration issue?
    All,
    Last year I did a major waterline re-tiling on my 1970s concrete pool using researched proper thinset, etc. Upon opening I found the upper most waterline tile has popped off in many areas. I have a few questions: 1) behind the top most waterline tile there is a definite visible line where the coping meets the pool wall/beam - I may have tiled over this gap and wonder if either moisture or shifting caused the problem of ataching to two seperate surfaces and, if so, should I only replace the tile only on the pool wall and stop just below the gap (demarcation between beam and coping)?; If the answer to #1 is to not tile across this gap can I use an epoxy versus thinset for these 2w x 6l tile and if so what kind is recommended (I've heard of using 3M Marine sealant 5200...)?; 2) The gap between the uppermost waterline tile (asuming I stop below the gap described above) will be over and inch in some places - what type of caulk or material do I use to fill that gap?; 3) There is a 1"-1.5" gap between the coping and decking that was old and tired - I pulled it up and it had backing rod below. The backing rod was wet as was the sand below - should I skip the rod and replace with a self-leveling Velcuum contractor caulk which may help keeping moisture seeping below the coping?
    Default Re: Old Concrete Pool - Post-restoration issue?
    I am not the resident pool building expert around here, but somebody will be along shortly who can offer you some advice.
    I just wanted to welcome you to the forum!
  1. In-ground Pool Restoration
    By goodgrimes in forum In-Ground Pool Construction and Repair
    Last Post: 06-17-2014, 07:15 PM
  2. First post - hayward pump issue
    By bdpeter in forum Pool Equipment & Operations
    Last Post: 05-30-2013, 04:19 PM
  3. Concrete Pool Scaling Issue
    By rfdowd in forum In-Ground Pool Construction and Repair
    Last Post: 08-22-2012, 08:19 AM
  4. Fiberglass in ground pool restoration
    By mcgoughman in forum In-Ground Pool Construction and Repair
    Last Post: 03-01-2012, 12:00 AM
  5. Restoration of pool
    By Cbw2121 in forum In-Ground Pool Construction and Repair
    Last Post: 01-25-2012, 08:59 PM
