Re: 1st time pool owner
ill need to remember that in case i mess up at some point along the way. im sure it is only used in small amounts right? maybe a few cap fulls? or are we talkin cups?
well now that the pool is starting to come around i have a few questions.
at which point will stop shocking the pool to 10+ppm and bring it down to 1-3ppm?
i also decided to have a look at the solar blanket, and it is kinda rough. i didnt unroll it completely but i saw a few hole and tears and it seemed a little bit brittle. should i be looking into getting a new one?
i have also notices that the pump has a minor leak and i am assuming it is a seal. i have been looking at used pumps and am wondering if i should keep it at 3/4 hp, or maybe go up or down a notch?
any pump i should stay away from?
right now i have 3/4 jacuzzi pump and jacuzzi sand filter.
