Re: New to BBB
First off, let me say welcome to the forum! We're glad to have you here!!
The first thing I see in looking at your numbers is that your pH is too low--anything below 7.0 runs a risk of damaging your liner. So a priority for me would be to get the pH up, and I would do it using 20-mule team Borax from the laundry aisle at WalMart. (green box). I would start with about 2 cups, dissolved in water and then poured slowly down the skimmer. Give it a couple of hours to circulate, then retest for it. Many pH test blocks only go to 6.8, and if that's the case, your pH could well be below that, so after you test, you can add more 1-2 cups at a time until you get the pH into the 7.2-7.6 range.
When you say you've added 2 bottles of stabilizer, are you talking about the granular type? If so, did you add it through the skimmer or broadcast into the pool? The granular type is very slow to dissolve and register on the tests, so we usually recommend that you add it, through the skimmer or in an old sock tied in front of a return, and then wait 4-5 days to retest for it. The problem with testing and adding too quickly is that, by the time it does register, often you've overshot your target and either need to drain/refill some water or use higher chlorine levels to compensate.
I'm assuming the active ingredient in the stabilizer you put in is cyanuric or isocyanuric acid--if not, then we really need to know what it was. Also, what is the total amount of stabilizer in each bottle?
Regarding the cloudiness of the water--looks like you might have an algae bloom trying to start..if your FC =1 and TC =3, then you have a CC of 2 and need to shock the pool. If the CYA is 0, then you need to raise your FC to 10-12 ppm and keep it there until the pool clears. Run your filter 24/7 while doing this, and backwash it as needed when the pressure rises as the dead algae is filtered out.
I know it's a lot of information to process at once, but once you get a grasp on it, this method of pool care is really very easy to maintain, and LOTS cheaper than the alternatives!
