Results 1 to 10 of 15
Thread: Anyway to not open the pool this summer?
    May 2010
    Default Re: Anyway to not open the pool this summer?
    Thanks for the detailed reply. My pump is a 120v unit with a sand filter. I could get everything all hooked up and setup with a timer to circulate the water. Would there be anyway to leave the winter cover on through out the summer. My backyard is terrible with the trees and anytime we get any type of wind everything seems to collect in the pool.... I have someone that can check on the pool while I am gone but I don't want to hassle them with having to get all the cleaning equipment out all the time.
    Honesdale PA
    Yes to leaving the cover on. My thinking is that would keep the temperature a little lower maybe, keep the debris out, and keep sunlight out which should help slow algae growth. Maybe every few weeks or so it may help to have your friend shock it.
    May 2010
    Thanks again for the info. Hopefully it will work out with leaving the cover on. Alot of great information on this forum. Thanks again!
    The only thing about shocking it with the cover on is that the fumes may damage the cover. If it is easy, maybe they can lift up a corner of the cover for awhile after shocking to let it vent and then recover it a day or two later? (Make sure you aren't expecting stormy weather at the time the corner is peeled back so the wind won't get under it and pull it off.)
    One other thing, you might want to add some Polyquat 60% algaecide. It doesn't do too much for you if you already have algae, but it is a pretty good preventative.
    OK. After I posted above suggesting that you use Polyquat 60% algaecide, I started thinking -- filtering will just remove the polyquat. So, I talked to Ben about your situation, and here is his recommendation for you:
    I would use polyquat to maintain an unopened pool in summer. But the process I'd follow is this:
    1. Hold the chlorine above 10 (if vinyl, not too far above!) for a few days with the cover partially off. After the first day or two brush the pool to make sure you have exposed any algae.
    2. Let the chlorine drop to 3 and replace the pool cover.
    3. Let the chlorine continue to drop to 1, and then begin adding weekly maintenance doses of of polyquat.
    4. If there's a pump timer, operate for 2 hours, 2x per day.
    5. Both filtration and chlorine remove polyquat. So low chlorine and low filtration extend polyquat's life.
    6. If clarity drops -- use a waterproof flashlight at night -- filter full for 24 hours.
    7. If there's a slimy feel to the vinyl walls, or any sign of algae, restart the process.
    There are other ways, but that should work.
    May 2010
    Thanks again for the replies. I will have to try to do this with the cover on. I realize this may not be the best solution but I will not be the one doing the work and really would hate for the person doing it to go thru all the hassle with it. The pool has the fencing kit around the whole perimeter of the pool so just undoing the cover is a pain. The plan is get the pump hooked up next week and see how bad the water is, then go from there.
    May 2010
    Central NJ
    I am no mod, so they are giving you the best info. But... this is a losing proposition, PERIOD. Unless you have someone to MAINTAIN the pool, you are screwed. It is just like your house. I spent years as a state licensed inspector, and one of the most important things I learned, "there is nothing more damaging than vacancy!" You would be better off with meth-head tenants than vacancy. You will be able to fix the broken-ness when you come back, but IMO, plan on ZERO intervention. Deal later with 100+ gallons of bleach and maybe a little touch of silver? There isn't a way to have both, a clean pool and vacancy. Heck, just keep water in your gas traps! I don't mean to be bummer post guy, but IMO, you are having no choice, don't even think of keeping up, the stress isn't worth it, just know that the pond can be fixed. We did it. Addition and all kinds of things, got weird with frogs keeping us up all night, then nothing... Quiet. Dead quiet. Then we saw "Nessie." She (it?) was half the size of a man hole cover, a snapping turtle. Never heard a frog again.
    Good luck! Vacancy is the toughest of all. But the green eco-friendly/bio-hazard just behind your house can be recovered, I promise! I have done it!
    PL
