Results 1 to 10 of 21
Thread: New here. A bit overwhelmed.
    May 2010
    322 Church St
    Default Re: New here. A bit overwhelmed.
    ok. This is what numbers were on the sheet I got from the pool guy.
    pH: 7.2
    TA: 280
    Calcium Hardness: 225
    CYA: 0
    Phosphate: 0
    Does this help? (The kids are going to hang me if they don't get to swim soon....they are getting a crazy look in their eye!)
    Have you added any chlorine or do you have any chlorine readings? Since it is well water, I am concerned about telling you to shock the pool without knowing if you have any metals in your water. For now, don't shock but simply add 2 quarts of plain bleach. That should take your chlorine up to 6. You'll probably need to do this a couple of times per day for right now. I'm going to ask Marie to take a look at this. She is the one who knows more about metals. You also might want to take a sample to be tested for metals. Then, you'll know for sure if that is going to be an issue for you.
    As for lowering TA, the process is to drop the ph with muriatic acid (which will also drop the TA some) and then aerate the ph back up. Then, repeat the process until you get the TA where you want it. Since your ph is already 7.2, you don't want to drop it any further right now. Go ahead and start aerating until the ph climbs up to at least 7.6 or 7.8. Then, you'll do some muriatic acid to lower it back down to 7.0-7.2 and aerate again. Repeat as necessary. (In a pool this size, 5 oz. of muriatic acid will lower the ph by approximately 0.2)
    You'll also need to buy some stabilizer (cya) to add or use triclor tabs to chlorinate with for awhile. (If you use tabs, make sure they do not have any copper in them.) Also, if you do decide to use the triclor tabs, monitor your cya level because the tabs will add cya. When you get to around 30-40, stop using them and switch to using bleach. I would suggest not using cal-hypo as your calcium hardness reading is already 225.
    P.S. --- I understand the crazy look in their eyes from wanting to swim, but usually around my house, it is MY eyes that have that crazy look. I am the one who is usually most anxious to swim! Let them get in!!!
    May 2010
    322 Church St
    Just to be sure....all this applies to the swg as well? Are there any differences I need to be concerned about with the swg?
    Thank you for all your help this far. I've been areating the pool already so hopefully it will be up a bit by the time I get home. I'll pick up a nice kit as well.
    The bleach that Watermom recommended is to get your chlorine up for right now so that you don't add an algae bloom to the equation. Once your SWG gets up and running, it will generate the chlorine for you, but in the meantime since you don't have any stabilizer in the water, the sun will quickly degrade your chlorine.
    As far as the other recommendations from Watermom and Carl, they all apply even with the SWG running--in fact, the SWG will help raise your pH as well, so it actually will make your job a little easier.
    Also, you do need to add CYA to the pool, but do NOT add 3 lbs to a 6500 gallon pool. You want to check the CYA level that your SWG manual recommends, then follow CYA label directions to target just below that level, since CYA takes several days to register in the pool, and it's easy to overshoot....and if you do that, then you'll have to drain/refill to lower it. If you have a sand filter, you can put it in the skimmer but don't backwash for at least a week, or better yet, put it in an old tube sock or knee hi and hang it in front of your return to let it dissolve.
    BTW, a pool full of splashing kids is a VERY efficient way to raise your pH!!
    Welcome to the forum!
    May 2010
    322 Church St
    Ok. For now I will shock, condition, and put keep an eye on the pH. As the pH goes up a bit I'll add the acid to get it down to 7.0 and continue to "ratchet" the TA and pH to where they need to be. Thanks again for the help. I look forward to being a part of this forum.
    May 2010
    322 Church St
    As I mentioned in my post above, since you are filling from a well, you don't want to shock until you make sure you don't have any metal in your water.
    Ok. No chlorine until I check for metal.
    mbar's Avatar
    Ashland, PA
    You may want to add a sequestering agent before you shock. Anything that says metal out, or metal control. If you have metals in the water, and high ph and you shock you will cause the metals to fall out of solution and stain the pool (it can be cleared up, but to stop it before it happens is much easier!). Put as much as it says on the bottle in, and you will have to add it as you add water to your pool. The sequestering agent will keep any metals in the pool water in solution. High ph along with high chlorine levels is what makes metals fall out of solution. If you have any questions feel free to ask
    Northeast PA
    It is ok to add chlorine. As I suggested, take it to about 6ppm but just don't "shock" the chlorine up high. You might need to reread this thread. There has been a lot of information given and sometimes it is hard to absorb it all on the first read. Hang in there. You'll get it. Let us know when you find out about your well water.
    May 2010
    322 Church St
    OK. I'm sorry...I was a bit confused (I thought that "shock" was Chlorine)
    When you say "plain bleach" do you mean just "plain bleach"? Like from walmart?
