Results 1 to 10 of 17
Thread: Ph v ta
    May 2010
    Default Ph v ta
    I have what might sound like a stupid question. My PH tends to hold pretty well. But my TA tends to run high, around 160. When I add acid to lower TA, it drives my PH down also. Is there a way to lower TA without changing my PH? Which is more important to worry about. I have a plaster pool which I just re-filled to lower CYA. It looks fantastic right now. Chlorine level is steady and the water is very clear. I have checked it several times a day and all is good except the TA is high.
    Default Re: Ph v ta
    You said you have a plaster pool? That changes things.
    You need to start lowering your T/A to 120-125 as your upper limit. For a vinyl pool 180 seems to be the safe upper end.
    Look up our thread on lowering T/A via the ratchet method (you "ratchet" it down).
    You lower pH with acid, which brings T/A down with it. Then you aerate to raise pH without T/A rising again.
    Now you "ratchet" T/A down by lowering pH again, then aerating to raise it.
    I'd aim for 100 as my target if I were you.
    May 2010
    Default Re: Ph v ta
    OK...I add acid to lower PH which lowers TA. That much I understand. I do it in stages so as not to go to far.But how do I "aerate" the pool. I have never done that and am not sure what that means.
    May 2010
    Default Re: Ph v ta
    waskydiver, not so interested in perfect numbers as much as I am concerned that with the plaster pool, the high TA could cause problems.
    Default Re: Ph v ta
    To aerate, you can turn your return jet eyeballs upward to create rippling/bubbling on the surface. Or throw in a bunch of kids to play around. Anything that causes splashing will aerate.
    May 2010
    Default Re: Ph v ta
    I've never heard of aeration before, does anyone have an idea how it raises pH??
    May 2010
    Default Re: Ph v ta
    Well thats easy enough...thanks
    Default Re: Ph v ta
    Quote Originally Posted by wposton84 View Post
    Not sure of the chemistry, but there's a gasification process that turns an acid into a hydroxide by the removal of, I think it's CO2. Chem_Geek has the whole chemistry of it down pat.
    If your T/A and your CH are both too high, it's easy to get cloudy water. For plaster pools, usually a CH of 200 to 400ppm is recommended. But if your CH goes to 500pm and your T/A rises, then you'll get cloudy water.
    Most vinyl pool owners don't have high calcium so it's not a problem if T/A is higher.
    Default Re: Ph v ta
    The short answer is that carbon dioxide in water is carbonic acid so when you are removing carbon dioxide from the water you are effectively removing carbonic acid -- removing an acid raises the pH. For technical reasons I won't get into here, the TA does not change.
    Default Re: Ph v ta
    Thanks for the SUPER-simple and clear explanation, Richard. I think I finally understand how the aerating raises pH!
