Results 1 to 10 of 11
Thread: backwash water goes into pool
    May 2010
    Default Re: backwash water goes into pool
    We do have the manuals for all the equipment, but it never mentioned a rinse option and it's not marked on the equipment. The only "sight glass" is a crummy old piece of semi-transparent hose they installed as part of the backwash pipe. I don't think you could really see through it well enough to decide when to stop backwashing. We usually stop when the pressure is back to starting level of 10.
    As I said, there is a person coming to give us a regular backwash hose, so maybe that will help us be able to monitor the water that is coming out better. I'm going to ask that person's advice on this problem, too, however I've started to distrust some of the professionals in the pool industry. That's why I am asking here first! Thx...
    Lehigh Valley, PA
    One simple way of telling when the filter is clean during the backwash operation is to catch some water in a white plastic pitcher. When you see few or no particles, you're done.
    That there's no rinse setting on the filter is odd. Backwashing pushes water into the bottom of the filter and really stirs up the sand. The rinse cycle then packs the sand back down. From my own experience I know that if I didn't rinse for 30 seconds I will get some sand in the pool.
    That is what I am concerned about, too. Even when they think they have the water coming out the backwash hose looking clean, I'm afraid they will still get a blast of sand back into the pool. Maybe call the filter manufacturer and ask them about this problem?
    May 2010
    I was thinking maybe it would help to wait 20-30 minutes to let everything settle down inside the filter before turning the pump back on. I don't know... I will ask the pool guy and let you know what he says. Thanks!
  1. water is not circulating / cannot backwash
    By coolpoolguy in forum Pool Equipment & Operations
    Last Post: 10-31-2010, 10:22 PM
  2. Slow Water on Return and Backwash
    By mohawk in forum Pool Equipment & Operations
    Last Post: 08-28-2007, 10:15 AM
  3. Backwash hose-Walmart vs Pool Store
    By hoffmans in forum Above-Ground Pool Construction & Repair
    Last Post: 06-04-2007, 05:44 PM
  4. Zeo in Pool after backwash
    By rrands in forum Pool Equipment & Operations
    Last Post: 09-29-2006, 12:59 PM
  5. Reduction of Backwash water loss ideas.
    By JohnT in forum Pool Equipment & Operations
    Last Post: 06-05-2006, 07:30 PM
