Closed Thread
Results 1 to 10 of 10
Thread: Green, Cloudy, Disgusting Pool? You have ALGAE!!!
    Ontario.
    Default Re: Green, Cloudy, Disgusting Pool?
    Vacum to waste, so the dirty gunk goes down the drain instead of to the filter.
    bbb is offline Registered+ Thread Analyst bbb 0
    CarlD's first post here should really be crossreferenced to a sticky at the top of the Algae forum - since it is really a great post about how to clean up from an algae outbreak.
    bbb = bleach, borax, & baking soda
    Jun 2010
    southern in.
    Default Re: Green, Cloudy, Disgusting Pool? You have ALGAE!!!
    if u have a filter how do u vacum and not get the water back in the pool.
    You don't. The dirt, dead algae, etc. is removed by the filter and the water is returned to the pool. However, if you 'vacuum to waste,' the water is pumped out through your backwash line instead of going into the filter.
    Jun 2011
    Do you have to vaccum everyday? Will it eventually get clear with filtration and brushing?
    No. You do not have to vac every day. Dirt that is settled on the bottom usually will not reach the filter unless it is stirred up though. How often you vac just depends on how quickly your pool gets dirty.
    If this discussion needs to continue, let's start a new thread instead of tacking on to the end of this "sticky."
    Thanks.
Closed Thread
