First off, welcome to the forum! There is good news and bad news. The good news is that since this is a fresh fill and you don't really have any cya (stabilizer) in there yet, the chlorine isn't gonna last long and will be lost to the sun pretty quick. Can't say that it will be by this evening but if it is a hot, sunny day, you will lose a lot of it.
The bad news is that there isn't really anything to do other than wait for the sun to deplete the excess chlorine other than drain and refill.
More good news is that i have a feeling that by evening the chlorine level will have come down dramatically. Even more good news is that even if the chlorine is still SOMEWHAT HIGH, it is ok to swim (with an old suit that it isn't gonna matter if it fades). Of course, if it is EXTREMELY HIGH you won't want to do this. We'll wait til this evening to see what the level is to call this one.
I assume that your test kit will only register to 5. Right? To get a better idea of what your chlorine level actually is, use our "dilution method." It is not super accurate but will at least get a ballpark figure for you.
Take one part pool water and one part DISTILLED water and mix them. Use this to fill your test vial and then test as usual and multiply the results by 2. If this doesn't take the scale high enough to help, take one part pool water and two parts distilled and multiply by 3, etc.
After you have done this, repost with numbers. Actually, a complete set of current water testing results would be a good idea for us to look at.
What time are you expecting little swimmers today?
Hope this helps.
By the way -- I edited your thread title a bit. Hope that won't be a problem for you. Again -- welcome. Glad you found us!
