Thread: Cloudy Pool
    May 2010
    Default Cloudy Pool
    Happy Memorial Weekend and thanks in advance for your assistance!! I'm brand new to pools and finding people to be very helpful. Kind of like owning a jeep, it's a pool thing.
    Here it is. Pool has been open for 6 days. Chlorine is good 3.0, ph is borderline high 7.8. Water is CLOUDY. Filter has been running for 4 days with no change. Clarifier hasn't made a difference. Now what?
    Default Re: Cloudy Pool
    Hi and welcome! First of all, don't add anything else to your pool yet other than chlorine when needed. Post a full set of complete water testing results and let us look at them. Use a drops based kit -- no test strips. Walmart sells a 6-way kit that will test what we need for the time being until you can buy a good kit. We recommend a Taylor K-2006. Repost with more numbers and more specifics about your pool and pump/filter and somebody here can help you out.
    Also, tell us exactly (ingredients -- not just "shock") of what all you have put in your pool thus far.
    Just to clarify, what Watermom is asking for is drop-based readings for:
    Free chlorine
    Combined chlorine (if you have it available--a pool store test should give you this)
    pH
    Total Alk
    CYA (same as stabilizer)
    Calcium Hardness
    If you don't have a test kit immediately available, you can take a sample to the pool store and get it tested, JUST DON'T BUY THE LIST OF STUFF THEY'RE GONNA TELL YOU THAT YOU NEED!
    Welcome to the group!!
  1. From cloudy green to cloudy blue
    By Dydylynn in forum Dealing with Algae & Slime
    Last Post: 06-10-2012, 06:09 PM
  2. Cloudy ,Cloudy,Cloudy... for a week now.
    By uwinsome in forum Dealing with Algae & Slime
    Last Post: 07-14-2011, 06:55 PM
  3. Cloudy Pool
    By Dirtboy6 in forum Pool Chemicals & Pool Water Problems
    Last Post: 04-26-2011, 07:32 PM
  4. Cloudy Pool
    By dustybecca in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-01-2007, 02:35 PM
