Results 1 to 10 of 21
Thread: Sky Blue water - cloudy going on 4 weeks
    May 2010
    Unhappy Re: Sky Blue water - cloudy going on 4 weeks
    Many Many thanks for your help and I read for hours before posting - so much informative info.
    So now i'm getting the info but lack wisdom - kids these days
    In my rush for power and glory I went to the pool store after i posted.
    My pool is 36k gallons. Here are the stores test results and my 82.00 purchase in chems and a good test kit. I'm probably upto 350.00 so far at least in pool store chems.
    FAC - .5
    TAC - 2
    PH - 7.0
    TA - 100
    Cal Hardness - 150
    CYA - 20
    the 82.00 went to
    1. 8 gallons of liquid shock - all poured in 15 minutes ago as instructed because of some " lock " in my pool ? ok whatever
    2. Fiberclear - DE to add to skimmer and raise psi by 1 using small handfulls to filter small particles - todo later today as instructed.
    3. Deluxe test kit using the drops that tests the above.
    They did not test for TDS/copper/iron/phosphates or salt
    He suggested that I come back later today and buy the chem to raise the ph more.
    Upon opening I set 3" puck feeder on 5. brush/vaccum to waste etc - same as usual
    Then used the standard opening kit from the pool store.
    Apologies if i'm a little loose on the terminology(but i'm a quick learner).
    I would really like to use / borax,bleach etc as the chem ingredients are the same from what I've read and understand. I'm off to Wallmart for the 20 Mule, cool name BTW hehe.
    Again - many thanks for the assistance !!!! Will keep you posted as the day goes on - I want 1/2 gainers off the board and cold beer - todays gonna be a beaut !
    quick question - will clorox harm or bleach my vinal liner ?
    Rob
    Default Re: Sky Blue water - cloudy going on 4 weeks
    Bleach will not harm or bleach your vinyl liner, as long as you are controlling the amount you're adding, and not just throwing stuff in the pool to try to clear it. (I know the temptation is there, but RESIST IT! )
    Keep in mind that the pucks in the feeder are trichlor, and it is raising your stabilizer (and therefore your baseline chlorine) by the minute. Most people target 20-40 ppm CYA in their pools, but you don't really want it to get higher than that, so keep an eye on it. Also keep in mind that those trichlor pucks are driving your pH down, so you're having to both raise your pH AND compensate for the trichlor lowering it at the same time...in your position, I would remove the trichlor pucks and switch to bleach or liquid chlorine. In the meantime, the pH rise stuff the pool store wants to sell you is overpriced Borax, which is in a green box in the laundry aisle at WalMart. Add it as Watermom directed to get your pH back up to the 7.2-7.6 range.
    In a 36K gallon pool, each 3 quarts of 6% bleach you add will raise your chlorine by 1 ppm. Keep in mind that free chlorine (available to work) + combined chlorine (already working, thus being used up fighting something in your water) = Total chlorine. When your combined chlorine is greater than .5, that usually means you're fighting an algae bloom, hence the cloudiness. To fix that, raise your chlorine to 12-15 ppm and keep it there until the CC goes to zero, and your water clears. Do this by testing and adding more bleach 2-3 times daily (or more frequently if you can). The more consistently you keep the chlorine at this "shock" level, the quicker your pool will clear. Once the pool is clear and the CC is back to zero, you need to not let your chlorine get below 2 ppm--you need to keep it between 2 and 5. (That is, unless you keep using the trichlor and raising your CYA, in which case those numbers are gonna need to shift upward according to the best guess guidelines:
    Stabilizer . . . . . . Min. FC . . . . Max FC . . . 'Shock' FC
    => 0 ppm . . . . . . . 1 ppm . . . . . 3 ppm . . . . 10 ppm
    => 10 - 20 ppm . . . . 2 ppm . . . . . 5 ppm . . . . 12 ppm
    => 30 - 50 ppm . . . . 3 ppm . . . . . 6 ppm . . . . 15 ppm
    => 60 - 90 ppm . . . . 5 ppm . . . . . 10 ppm . . .. 20 ppm
    => 100 - 200 ppm . . . 8 ppm . . . . . 15 ppm . . .. 25 ppm
    So--you've already put 8 gallons of chlorine in (any idea what the percentage is, and have you tested it since the chlorine addition?) , pouring slowly in front of a return jet so that the chlorine disperses and doesn't splash on your liner, so now keep your pump/filter running 24/7, and then keep the Cl at 12-15 by making frequent additions of bleach until the CC is down to zero. In the meantime, go ahead and adjust your pH as Watermom described.
    Do not worry about TDS, salt, phosphates, or any of the rest of that--you obviously don't have iron or copper in the pool if it didn't stain when you added the liquid chlorine, so none of those things are gonna apply to you--it just gives an indication to the pool store people of more useless stuff they can sell to you!
    Welcome to the forum!!
    Good advice from Janet. Fight the urge to be "doing something." Other than adding bleach and Borax, nothing else should be going into your pool right now. Many times, people are so intent on clearing their pools that they end up making things worse by adding every product on the shelf at the pool store that the teenager behind the counter recommends. Bleach, Borax and patience are what is needed now. Keep us posted how things are going.
    May 2010
    Hi all - quick update
    Earlier today, Mrs. Heaven had the big box of 20 Mule in the garage. I added it slowly into the skimmer.
    It appears my ph levels are exactly the same after a testing about 15 minutes ago.
    I will head to the store and get Borax/Bleach until I start getting some movement there.( well in a while - those daquiris kick ya in the booboo !
    Also CC was very low but TC was around 3 or 4 id guess by the color. When I stand in the pool i can see my feet which is better than yesterday already.
    From your help, i'm confident i'm on the right track TYVM !!!!
    The water feels very nice almost silky if that is a good description.
    Cheers !
    Rob
    P.S. The psi went up a bit so i backwashed/rinsed and back to 11 psi which is normal for my system.
    Have not added DE yet. The 8 gal liquid chlorine was 12.5%
    I have also turned off the feeder.
    You want CC to be low. Ideally you want it to be zero. CC is combined chlorine or chlorine that has "already been used up" oxidizing something. Keep at the Borax and since the water is still cloudy, the cl level needs to be higher as well.
    May 2010
    Thumbs up Re: Sky Blue water - cloudy going on 4 weeks
    The pool is clearing by the minute !!! words cannot describe how much I thank you !
    The PH is still a little low so i'm still working on that, but the CC/TC levels look great and held over night even after the storm dropped about 2".
    Major storm caused havoc here last night(loss of power for 8 hours) so i'll be cleaning most of today.
    I can see the shallow end perfectly and all walls in the deep to about 4-5'
    Just added more 20 Mule and will test in a few hours !
    Kiddies were in all day yesterday and had a blast - thats what its all about afterall !
    Rob
