Results 1 to 10 of 21
Thread: Sky Blue water - cloudy going on 4 weeks
    May 2010
    Default Re: Sky Blue water - cloudy going on 4 weeks
    Hi all - quick update
    Earlier today, Mrs. Heaven had the big box of 20 Mule in the garage. I added it slowly into the skimmer.
    It appears my ph levels are exactly the same after a testing about 15 minutes ago.
    I will head to the store and get Borax/Bleach until I start getting some movement there.( well in a while - those daquiris kick ya in the booboo !
    Also CC was very low but TC was around 3 or 4 id guess by the color. When I stand in the pool i can see my feet which is better than yesterday already.
    From your help, i'm confident i'm on the right track TYVM !!!!
    The water feels very nice almost silky if that is a good description.
    Cheers !
    Rob
    P.S. The psi went up a bit so i backwashed/rinsed and back to 11 psi which is normal for my system.
    Have not added DE yet. The 8 gal liquid chlorine was 12.5%
    I have also turned off the feeder.
    You want CC to be low. Ideally you want it to be zero. CC is combined chlorine or chlorine that has "already been used up" oxidizing something. Keep at the Borax and since the water is still cloudy, the cl level needs to be higher as well.
    May 2010
    Thumbs up Re: Sky Blue water - cloudy going on 4 weeks
    The pool is clearing by the minute !!! words cannot describe how much I thank you !
    The PH is still a little low so i'm still working on that, but the CC/TC levels look great and held over night even after the storm dropped about 2".
    Major storm caused havoc here last night(loss of power for 8 hours) so i'll be cleaning most of today.
    I can see the shallow end perfectly and all walls in the deep to about 4-5'
    Just added more 20 Mule and will test in a few hours !
    Kiddies were in all day yesterday and had a blast - thats what its all about afterall !
    Rob
    Jun 2010
    Maryland, outside of DC
    Great thread. I'm experiencing the same problem and everything that has been said has been helpful. I am going to follow what was said for the others. My question is what product can I use to raise the alkalinity. Right now I'm at 45. My CYA is 50, Ph 7.2, FC 3. I don't want to buy one of the Pool Co. products for fear of what else it may do. Is theree a "pure" prooduct I can add.
    Hello, Alemeg, welcome to the forum!!
    Just wanted to add a caution that your Cl is on the low end of recommended for a CYA of 50--don't let it get below 3!
    May 2010
    Thumbs up Re: Sky Blue water - cloudy going on 4 weeks - Update
    !Update!
    Following the instructions given here, has led my pool to a level of clarity thats simply amazing.
    The level of expertise and assistance here is awesome.
    1. I took a deep breath relaxed, and bought a good test kit.
    2. Blocked out all family members / neighboors / Pool Store advices.
    3. Kept my chemical levels up to treat my particular issue with constant monitor simply using the BBB method.
    Result ?
    A crystal clear pool that my family, frends and neighboors are enjoying. No eye irritation, complaints from parents the next day or rash on their kiddies skin, and a tan that rivals Hassleholf.
    Thanks and HAGS ! (have a good summer)
    Rob
