Thanks Torontonian...well said.
Pool Master, are you in the pool service industry by any chance?
First, most do not taste the salinity in the water. AND BY NO MEANS IS IT SEA WATER concentration (as implied by your "YUK" response). Most will comment that the salt water feels better on their skin than a non salted pool. Although some will also say that they don't feel a difference.
There are different types of systems, depending on if you're looking for basic salt chlorinators, inbetween, or bells and whistles (automation with regards to your chlorine and pH levels; pump control; remote interface, etc).
Then you have several model cells to choose from, within each manufacturer's offerings. The larger the cell, the more chlorine you can produce and the longer the cell will last. There is a cost with replacement cells when they wear out. Typically this is around 10,000 hours of operation. For So Florida and our 12 month seasons, this is about 3-5 years...I live in Coral Springs, FL.
Other than the initial cost of the system, your ongoing cost is very inexpensive. Replenish the salt and stabilizer when levels drop, which would be due to water loss from bather splashout, bathing suit dragout, filter backwashing (if you have a DE or Sand filter), rain fall overflow, and leaks. On a residential pool, this may be 2 -3 bags a year of salt. A bag of salt is anywhere from $5 - $10.
What's needed to convert your chlorine pool? Add the salt clorine generator equipment and salt directly into the pool. Depending on what your current salt level is (which may already have salt from bleach (sodium hypochlorite) usage. If your pool is new, or freshly refilled water, 50 lbs/2000 gallons gets you to 3000 ppm. This is the typical salt level for most systems offered in the US. Imported Australian systems run a bit higher in salinity.
You will still need to test your chlorine and pH levels, and adjust them as needed.
As stated, using a salt chlorine generator does not make your pool a salt pool, or a chlorine free pool. You're simply making your own chlorine, on site, and eliminating the need to have to run to the store to pick up chemicals week after week. It also creates a big convenience factor to maintaining your pool, giving you more time to enjoy it.
I DO WORK FOR AUTOPILOT CHLORINE GENERATOR SYSTEMS, www.autopilot.com, so you can take my response with a "grain of salt" as a salt industry rep.
Hope I've been unbiased.
