Re: New Pool Owner With High Iron
hi, sorry i haven't been on the forum - I'm in texas visiting my sister. If it were my pool, this is what I would do.
First if your ph goes back down to low, you can turn your return jets up. This will lower the alkalinity while raising the ph naturally. You want you ph 7.2 to 7.4. I would start to add bleach. Do not add anything other than the algacide. Just start adding the bleach slowly. Take it up to shock levels. If the stains start, add more sequestering agent. I am afraid that the pool is starting an algae bloom, and you are just fighting a losing battle. You can deal with the stains when you know that the water is sanitized. When adding water add it through the skimmer - so it goes through the filter first. It sounds like you should have enough sequestering agent in the water. See the problem is that sequestering agent uses up chlorine, and so does algaecide. So you will have a very big chlorine demand with all the chemicals you have in the water. The chlorine breaks down the sequestering agent and algaecide, so that is why you always have to add a maintenance dose of these chemicals. I know it sounds confusing, but the most important thing is to get the water sanitized. You can swim with stains, but not with unsanitized water.
1. Start to bring the chlorine up to shock level, which if you have no cya will be 10ppm.
2. Keep the pump running 24/7
3. You will have to keep adding chlorine or keep a puck in the skimmer because if it is sunny out the chlorine will just get eaten up with sun because you have no cya. Pucks have cya in them so they are stabilized chlorine, or you can add cya (stabilizer)
4. If you add a puck, your ph will go down, so you keep your returns up to aerate the water, which will bring the alkalinity down while raising the ph. I the ph goes below 7.0 add baking soda to go up 2ppm.
You will have to have a little patience with the staining. If you get the water in balance to swim, and you still have stains we can deal with them later.
I know this is long and confusing, but please feel free to ask any other questions you have - I am sorry it took so long for me to answer, but I will be checking the forum from Texas
Northeast PA
