The phone rep is wrong and is probably confusing the K-2005 which has a DPD chlorine test where you compare intensity of pink with the K-2006 which has a FAS-DPD chlorine test where you count the drops until the pink turns clear (i.e. uses titrants). As Watermom noted, the only difference between the K-2006 (A) vs. the K-2006C is in the quantity of reagent bottles where the former uses 0.75 ounces and the latter uses 2 ounces. So the "C" costs more but is more economical per test. You can get the K-2006 at a good online price here and can get the K-2006C here.
