Re: With your help.. we are going from mess to success!
Ok.. right now we are at:
FC: 2.2
TC: 17.5
PH: 6.8
TA: 120
CYA: 30
Water is clear, but a bit cloudy. I was able to vacuum again this morning (more dead algae). Now.. how long will it take chlorine levels to come down? Also, do I need to bring the level down before I let the pump rest overnight to let the debris settle to the bottom for vacuuming? Working on the PH, but can't seem to get it up there... not sure what's going on with that.. will add more Borax later this evening and see if that'll do the trick..
Anything else I might be missing?
