Results 1 to 10 of 11
Thread: Newbie Lighting Question
    Jun 2010
    Default Newbie Lighting Question
    First of all, I would like to introduce myself. My name is Dave & this will be my 2nd season of having a pool. I have a 20 x 40 gunite in ground. It is about 50 years old. The filter is a Nautilus 48 DE, with a Hayward pump system. Before I moved into this house, the pool was never closed.
    Last season, I opened it, battled the swamp, etc. I am a DIY guy, mainly by the size of my pocket book. I truly do like to do things myself as much as possible. This year my pump went bad. I went to my local pool guy who would only sell me a whole new assembly for $450. I found a local guy who sells rebuilt ones for $100 and guarantees it for life. I hate walking into the pool store, because they seem to always sell the most expensive things to me. I understand there are people who will pay that & more to have it installed. I can't do that at this oint in my life.
    That being said, the light has never worked for me. It is an 11" niche. I don't know the brand. Last year I tried to take it apart while the pool was full, but could not get to it. I am emptying the pool to a workable level now. I do know to this point that the problem lies withing the light itself. I tested the GFIC receptacle it plugs into.
    Could it just need a bulb? Can you get just a bulb, because I have only seen light/chord combos. I don't mind spending a little money, but some of the prices are outrageous. The other thing I am afraid of is that the previous owner somehow sealed it into the pool wall because of the difficulty I had when I first tried to take it apart. I did remove the top screw, but I could not budge the bottom one. Hopefully tomorrow I will have it apart.
    Sorry for rambling, I just want to make this work right, at an affordable price. The pool guys always seems to try rip me off and I am sick of it.
    Thanks-Dave
    Jun 2010
    Default Re: Newbie Lighting Question
    Well, this mornig I got the level down to where I can work with the niche. I took the screw out & it seems that did nothing. I think the previous owners had the trim ring plastered into place. I was going to get a picture, but was running late.
    I'm sorry that I can't help with your problem. Trust me --- you don't want to be taking any kind of electrical advice from me!! Not unless you want curly hair (at the very least!)
    The part of your post about being a DIY guy because of the size of your pocket book --- we can all relate to that. That is one of the great things about the Pool Forum. Everybody helping each other out which will usually save a lot of money!
    Just wanted to pop in here and say hi and welcome to the forum. Sit tight. Someone who can help you will be along shortly I am sure!
    Jun 2010
    Well my saga continues. Here is where it is now for those interested.
    I chipped away & removed the niche. It was indeed plastered into place. I got it all apart to the point where I have deduced that it is the actual socket itself. I am going to kepp taking that apart to see if I can replace that. If not, I guess I am going to have to throw in the towel.
    Thanks-
    Dave
    Jun 2010
    I opened up the fixture, wire brushed the contacts, & volia, it works.
    Now the fun part of putting it back in.
    Just wanted to jump in and add my welcome to the forum--I know less than Watermom about electrical applications around the pool so didn't dare try to offer any advice, but I'm glad you got it working again, and your post just might helop somebody else in the same position!!
    Glad to see you here...
    While I know quite a bit more than either 'mom or aylad about electricity and electrics, I know almost nothing about full voltage pool lights. Glad you have GFCI on it! I'm a big fan of the newer low-voltage lights. I have ones where the lens is part of the pool wall and you access the fixture from outside the pool.
  1. newbie question about jet pressure?
    By Txboynjgirl in forum Pool Equipment & Operations
    Last Post: 06-18-2011, 09:17 AM
  2. newbie QUESTION
    By rnjng in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-19-2006, 08:33 PM
  3. pool lighting/electrical question
    By ryanm in forum Pool Equipment & Operations
    Last Post: 07-04-2006, 07:04 PM
  4. Lighting and Returns Question (pic)
    By jhershauer in forum In-Ground Pool Construction and Repair
    Last Post: 07-02-2006, 12:27 PM
  5. newbie question
    By poolgal in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-17-2006, 03:58 PM
