Thread: Metals ? (You there Marie) ??
    stma is offline Registered+ Thread Analyst stma 0
    Poconos, PA
    Default Re: Metals ? (You there Marie) ??
    Thanks Marie....You helped me extensively a few years back....
    18ft AG Vinyl
    (waiting on my Taylor ReAgents to arrive)
    Simple drop test:
    TC 6
    PH 7.4
    TA 110
    CYA was added yesterday ( attempting a 40-50 range)
    After a swamp on Friday, 16 gallons of 5% has me perfect now... it's just the staining that "has me" once again. Was interested in the Jacks ONLY of their claim that it's stable in high CL numbers..... No doubt the metals will remain ,,, just want them to stay suspended...
    mbar's Avatar
    Ashland, PA
    You can use any sequestering agent with high chlorine levels. It is the ascorbic acid that wants the chlorine to be low, because chlorine eats ascorbic acid and so you would have to use more with high chlorine for it to work, and it is just a waste. While sequestering agent eats chlorine, it still works to sequester but you will use up more than usual. I just tried Jack's Magic the blue stuff this year. It clouded my water both times I used it, but it cleared up in a day or so. I used it when I had high chlorine levels and little bit of staining. It didn't lower my ph much, so I put in a puck and then the stains did lift. Hope this helps, let me know how you make out - we can all learn from each other how new products work
    Northeast PA
