Re: Fine Tuning a Salt Water Pool
O.K. Mom, to the best of my knowledge, every test I had done whether it was my own feable attempt at pool wizardry or tests performed the pool store said that my Total Chlorine and my Free chlorine were the same reading. I don't know if the pool store ever did a CC test. I assume that the Test Kit you recommend will have a CC test.
I was a little confused by the instructions in my own kit. If I do the first part of the test using tablet #1, the sample turns a pinkish color and is read on the scale next to the water sample. Here is where I am confused. If I am reading it correctly, it says to put a tablet marked #3 into the pink solution and compare the first reading with the new reading, which will only be readible if the sample got darker. Now, I would have thought that you would start with a fresh sample of water THEN drop tablet #3 into it to compare the reading.
Now you know how I got my name. Sorry Mom
