Results 11 to 12 of 12
Thread: The Long Road in Trying to Lower TA
    Stafford, VA
    Default Re: The Long Road in Trying to Lower TA
    Ben was right-on with his prediction. Thank you Lisa for seeking help for me.
    Fixed
    • Took Jandy DE filter apart and discovered that there as indeed a 2 inch whole at the top because the piece that fits into the manifold was crushed and down inside the filter panel. In fact, the whole panel was crushed to pieces.
    • Spent a good amount of time rinsing each panel individually. Boy were they all nasty.
    • Ordered the part immediately, but realized when trying to put it into the slot where the damaged panel had been that it was too big.
    • Ordered the partial panel immediately, and it fit perfectly. Within a week the pool water was no longer cloudy, and the skimmer socks weren't building up with cement looking goo. The new panel is shockingly white next to all the old panels.
    • Water is perfectly balanced.
    I still have DE problems, but I have decided to move to the Pool Equipment & Operations section for that.
    Thank you,
    Shannon
    34,500 gallon inground - Pebble Tec Tropical Breeze finish
    DE filter - Polaris vacuum
    BBB maintained since 1st opening in the summer 2006
    Saving for a winter pool cover-20'x40' surface
  1. Road construction causing pool problems?
    By whispering in forum Dealing with Algae & Slime
    Last Post: 08-13-2012, 03:45 PM
  2. Ph Lower after using BBB
    By Tillysaint in forum Pool Chemicals & Pool Water Problems
    Last Post: 09-13-2007, 12:52 AM
  3. Question for "down the road"
    By TxDan in forum Chlorine Alternatives: UV, Ozone, Baquacil (PHMB), etc
    Last Post: 07-10-2006, 10:15 PM
