Thread: Pentair Pool Light - Halogen Bulb Question
    Jun 2010
    NC
    Default Halongen Pool Light - Replacement Bulb Question
    I need to replace the Halogen bulb in my Pentair Aqua Lumins II pool light. Are the 120V/250W halogen bulbs at Lowes or Home Depot any different than the $25-$35 120V/250W halogen bulbs that the pool stores and pool web sites sell? At 2 for $7, I am hoping that the Lowes or HD versions are acceptable.
    Thank you
    Jun 2010
    NC
    Default Re: Halogen Pool Light - Replacement Bulb Question
    Hoping someone can weigh in on this one. Is there anything special about the halogen pool light replacement bulbs, or will the ones at hardware stores suffice?
    Honesdale PA
    Default Re: Pentair Pool Light - Halogen Bulb Question
    As long as the voltage and wattage is the same it should work. I'm convinced that Poolstores along with Boat shops and Harley shops have the biggest markups. Just look at the prices of hose clamps and PVC parts at Poolstores compared to Home Depot or Lowes.
    Jun 2010
    Smile Re: Pentair Pool Light - Halogen Bulb Question
    I'm not an expert by any means, but we have replaced 3 of these light bulbs (same Pentair lights as you have) w/ Home Depot or Lowes brands and have had success. Mind you, the wattage is not the same because we couldn't get 250 watt at the store. I didn't even bother to look online since these are working for us. Honestly, the amount of light is not diminished enough to be noticeable, and we have a 46,000 gallon pool. Good luck!
    May 2010
    Asheboro, NC
    Quote Originally Posted by Cinda View Post
    Heck, I pulled out my burned out 300 Watt, uber expensive, halogen bulb and replaced it with a 100 watt flood bulb that I had in my bins for 20 years. Less energy and the flood still shoots just fine, all the way to the steps. Shrug.
  1. Lower Watt Light Bulb
    By Phillbo in forum Pool Equipment & Operations
    Last Post: 08-06-2012, 05:19 PM
  2. Pentair Intellibrite 5g Light
    By CAH2873 in forum Pool Equipment & Operations
    Last Post: 04-09-2012, 01:15 AM
  3. Fiberstars 6008 lamp (light bulb) replacement
    By rjmo22 in forum In-Ground Pool Construction and Repair
    Last Post: 06-30-2011, 11:48 PM
  4. Pentair SAM Light Replacement
    By pjklifestyles in forum Pool Equipment & Operations
    Last Post: 06-06-2011, 11:13 PM
  5. Right light bulb?
    By KirstenHW in forum Pool Equipment & Operations
    Last Post: 07-07-2006, 11:39 AM
