Results 1 to 10 of 52
Thread: Need Help!
    Jun 2010
    Default Re: Need Help!
    The kit has shipped so hopefully I'll get it in the next couple of days. I have kept the chlorine level high as you suggested, but still no change. I am beyond curious to know what the calcium level is so if that's the problem I can fix it.
    Jun 2010
    Just got my test kit and the Calcium level or CH is 690ppm. From what I have read in the book that is way too high. How do I bring that down?
    Yep. That is high alright -- just what i suspected. The only way to lower it unfortunately is to do a partial drain and refill. Retest it one more time to make sure you got it right. Actually, why don't you go ahead and post a current set of all testing numbers for everything for us to look at.
    By the way, how does the water look today?
    Jun 2010
    I figured that would be your answer. We will have the other #s for you this afternoon.
    Jun 2010
    Here are the #s. They seem a bit off so I may need to get them again. However, the pool is being refilled now so I expect them to be different.
    FAC = 9
    TAC = 1
    PH = 7.1
    Alk = 80
    CH = 500
    CYA = 65
    I think you need to do a partial drain and refill. But, do NOT totally drain this pool! if you can drain about half, that should get your calcium level and your cya levels down to a more manageable reading. Then, I would not use any more cal-hypo. Stick with bleach. Watch your pH. It is pretty low. Don't want it below 7.0. or it can damage your pool. May want to add a cup of Borax to the skimmer slowly while the pump is running and see how high that will raise it. Anywhere from 7.2-7.8 is ok.
    Your chlorine numbers are not quite right. FC + CC = TC. So, your FC can't be 9 and your TC 1. Maybe try that test again.
    EDIT -- I just now reread your post and noticed you said it is being refilled. How much did you drain? After it is refilled, retest and repost with new numbers, but still -- keep an eye on that pH. It is pretty low.
