I think you need to do a partial drain and refill. But, do NOT totally drain this pool! if you can drain about half, that should get your calcium level and your cya levels down to a more manageable reading. Then, I would not use any more cal-hypo. Stick with bleach. Watch your pH. It is pretty low. Don't want it below 7.0. or it can damage your pool. May want to add a cup of Borax to the skimmer slowly while the pump is running and see how high that will raise it. Anywhere from 7.2-7.8 is ok.
Your chlorine numbers are not quite right. FC + CC = TC. So, your FC can't be 9 and your TC 1. Maybe try that test again.
EDIT -- I just now reread your post and noticed you said it is being refilled. How much did you drain? After it is refilled, retest and repost with new numbers, but still -- keep an eye on that pH. It is pretty low.
