Let me also add my welcome to you and glad to have you on the forum.
Seems like you have been adding a lot of things to try and help clear your pool. Sometimes (actually more like oftentimes) the more you add, the worse you make it. I would go with Janet's advice above and do a partial drain and refill and then shock your pool.
Don't use any more trichlor pucks. They are contributing to your cya problem. Even if you drain half of your water, your cya level is still gonna be pretty high at 75 but much more manageable. But, even at that level, you still don't want to use any more trichlor. (No dichlor shock powder, either.)
Cal-hypo is known for causing cloudy water problems. I'd probably just stick with liquid chlorine in this pool; either plain bleach or pool store liquid chlorine as they won't contribute to cloudy water problems.
I would also work on lowering the alk. You can see how to do this in the sticky at the top of the alkalinity forum called "How to Lower your Alk."
One last question --- why the Potassium Monopersulfate? More info about that can be found in the thread at this link. (Note post #2 within that thread.)
http://www.poolforum.com/pf2/showthread.php?t=3217
Again, welcome. Keep us posted how it is going and let us know if you have further questions!
