Re: Hopefully...minor clarity issue
If you're going to drain and refill to lower the CYA, do that first--it does not do much good to adjust all your other numbers to where you want them, and then mess them all up again when you refill. Do your draining first, then we can go from there to adjust the other stuff.
The sun and refilling will take care of lowering the chlorine, you don't have to do anything for that.
There are vinyl cleaners you can use for the skimmer walls--some people have had success with Magic Erasers, but I've just used a kitchen pot scrubber with a baking soda/water paste and it works fine for me.
And the best way to stay ahead of the chlorine draw is to add most of your chlorine at night--that way it spends all night working on the stuff in the water, and hopefully will reduce the chlorine load during the day.
