Results 1 to 10 of 20
Thread: Hayward Pump and Sand Filter Issue
    Thumbs up Re: Hayward Pump and Sand Filter Issue
    Kevin, I am so very happy you got this fixed!!
    I hadn't heard about that problem, but will keep it in mind, next time I run into a similar issue - thank you!
    I really hope the pool won't give you any more trouble, but would like to see you around here anyway
    Honesdale PA
    Default Re: Hayward Pump and Sand Filter Issue
    Glad to hear you solved the problem Kevin. Somewhere buried in the bowels of this forum I vaguely remember something about a variflow being plumbed backwards. Don't remember any other detail. Must have been a Hayward. Why do they do this stuff?
    Jun 2010
    Hatboro, PA
    I know the whole being plumbed backwards thing is odd. The guy at the pool store said it caught him off guard a few years ago. He'd did an install the day before and everything hooked up as expected. Did another install the next, hooked it up as he normally did, and the customer called a day later about a leak. He went back and noticed that the intake/outtake were switched. Swapped the connections and all was good.
    Glad he told me about it so I didn't open the box with the new Vari Flo I bought tonight and can return it tomorrow for a full refund.
    I'll be around as I'm sure others will post questions about things I've encountered in the past. And I definitely want to wean myself off of pool chemicals and use everyday things to save money. Everyone here is great and I'll be sure to pop in every so often.
    Kevin
