Re: brown walls and bottom
Hi, welcome to the forum! Your numbers are not too bad, but you can't have a Free Chlorine of 2 and a combined chlorine of 2 & a total chlorine of 2
Your free chlorine added to combined chlorine equals your total chlorine. Anyway you look at it a chlorine level of 2 is not high enough for a cya of 60. Here is a copy of the best guess chart:
Code:
Stabilizer . . . . . . Min. FC . . . . Max FC . . . 'Shock' FC
=> 0 ppm . . . . . . . 1 ppm . . . . . 3 ppm . . . . 10 ppm
=> 10 - 20 ppm . . . . 2 ppm . . . . . 5 ppm . . . . 12 ppm
=> 30 - 50 ppm . . . . 3 ppm . . . . . 6 ppm . . . . 15 ppm
=> 60 - 90 ppm . . . . 5 ppm . . . . . 10 ppm . . .. 20 ppm
=> 100 - 200 ppm . . . 8 ppm . . . . . 15 ppm . . .. 25 ppm
As you can see with a cya of 60 your minimum chlorine should be at 5ppms. Your shock level would be 20ppms. If you do have a combined chlorine level of 2 you will need to shock your pool - getting your chlorine level up to 20ppms and keeping it there until it holds within 2ppms overnight.
Did you test to see if the stains are metal or organic? You can do the vitamin C test - or you can also put some ph down in a sock and rub it on the stain. If the stain lightens or disappears it is from metals. If it is from metals then you want to keep the ph low and add sequestering agent before you take your chlorine levels up.
Northeast PA
