Re: I'm in big trouble - I turned water green
Hi Joe;
First things first . . . unfortunately, you've got several first things.
=> pH, chlorine, copper
FIRST:
Get a CHEAP drops test kit -- the kind that turns yellow for chlorine, and yellow to purple for pH, and test your pool. We need to know if your 6.2 pH reading is real, or bogus. Some pool stores might be able to test for pH; in others it's just going to be a bogus reading. I'd like to see YOUR readings, to either confirm or repudiate the pool store readings.
Verify that your pH is actually very low (yellow on the drops kit -- but don't confuse OTO drops (yellow = chlorine present) with phenol red drops (yellow = low pH). Don't test pH if the OTO drops turn orange: the chlorine / bromine is too high for phenol red to work well.
SECOND:
Dose with 1/2 gallon of bleach each evening, simply to maintain sanitation control a way least likely to conflict with anything else.
THIRD:
Assuming the pH is low, gradually start raising it, using 1/2 box of borax per 10K gallons, added every few hours. If you have a pump timer, disable it, and run your pump & filter 24/7.
FOURTH:
Answer some questions:
=> Do you have a heater?
=> Have you added any algicide, recently or last fall? What kind?
=> Do you have a Nature2, 'mineral' or any other gizmo that might contain or add copper.
FIFTH:
Do the fingernail scrape test I described, and include the results from that.
SIXTH:
Post your info, after you've collected it. Post the pH as soon as you've confirmed it -- if your pH is REALLY that low, and the color was yellowish-brownish-greenish, I know what it is.
PoolDoc
