Results 1 to 10 of 44
Thread: I'm in big trouble - I turned water green
    joecus is offline Lifetime Member Thread Analyst joecus 0
    Jun 2010
    nyc
    Default Re: I'm in big trouble - I turned water green
    Thanks -
    first - the 6.2 ph reading came from my local pool store. I have both the strips and the tester that you add yellow and red drops. I just took the strip reading, showing ultra low ph. The drop tester turns water yellowish when I add the red drops indicating a very lowph. I will work first on getting the PH up.
    second - I did the bleach
    third - I am running the filter 24/7 and will add borax (1/2 box ? what size box?)
    forth - I'm sure the copper came from the Algicide I added since this is when the water started to change color to greenish/yellow upon adding shock. Like I said, the water quickly turns back to clear. I do have a heater. The copper reading of 1.7 also came from my local store.
    fifth - I did the fingernail test on the black spots and it does dissipate.
    So, tomorrow I will work on getting the ph up using the borax, correct? Don't add the backing soda yet, correct? What about the alkalinity, don't worry yet? Is there a reason you don't want me to raise both ph and alkalinity at same time using baking soda? Lastly, what do I do about copper? Thanks a million, again. Did I forget anything?
    I'm gonna let PoolDoc address most of this with you but just a couple of comments. I think the only size of box of Borax that I have seen is 4lbs. 12oz. Don't put off until tomorrow adding the first 1/2 box of Borax. Go ahead and get it in there tonight. Low pH is REALLY bad for your pool. Critical to get it above 7.0 ASAP. After a couple of hours, retest and redose as needed.
    Also, baking soda raises alk a lot, but not the pH much. The low alk is nowhere near as critical as the low pH.
    PoolDoc will be by shortly to direct you further.
    EDIT -- Baking soda (sodium bicarbonate) and washing soda (sodium carbonate) are not the same thing. Washing soda is the same thing as soda ash.
    Also keep in mind that one side effect of dichlor is lowered pH.....
    Jun 2010
    nyc
    OK - borax is in. I will retest when I wake up. I will wait for other answers to questions.
    Thanks.
