Results 1 to 10 of 44
Thread: I'm in big trouble - I turned water green
    joecus is offline Lifetime Member Thread Analyst joecus 0
    Jun 2010
    nyc
    Default Re: I'm in big trouble - I turned water green
    Finally, the pool is clear and the chemicals are stable. I opened the filter and totally cleaned it out and ran the filter. Backwashed about 10 times before I got it clear. I noticed the earth in the filter had a light blue color. I've never had this. Is it related to the copper? I used "copper magnet" which is supposed to make it stable and protect equipment.
    Yep, blue is one of copper's colors.
    PoolDoc
    Copper oxide is black, copper hydroxide is pale blue, and copper carbonate is green though in practice mixtures occur so you get everything from blue to green. Then there is copper cyanurate which is purple/amethyst in color.
  1. Pool water turned green after shocking. How to clear it??
    By aces3 in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 06-29-2013, 09:56 AM
  2. Baking soda turned my pool green
    By BigStein in forum Dealing with Alkalinity and Calcium
    Last Post: 08-12-2007, 01:10 PM
  3. Water turned green after adding shock treatment
    By NowhereMan in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-11-2006, 12:25 PM
  4. shocked turned my pool green.. help!!
    By lulamink in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-31-2006, 10:45 PM
