Re: BBB method and vacation???
BeenPoolStored
Thank you, Anna! We do have an automatic chlorinator. Do you have any suggestions for how many pucks to put in the chlorinator and how high to run it on a scale of 1-10?
My own chlorinator's settings come in 1/8 increments. I fill it with pucks (it takes 7) and adjust the setting to 1/4. I do this because I've learned from past experience and usage of the chlorinator that the 1/4 setting keeps the free chlorine steady from one day to the next when nobody uses the pool.
It doesn't matter how many pucks you put in. They'll dissolve until the saturation point is reached inside the chlorinator which then dispenses the chlorine solution into your pool.
My setup is this:
7 trichlor pucks
chlorinator at 1/4
pump run time 7 hours out of 24
Those 7 pucks last for at least 2 months. When I'm not using the auto-feeder I just shut it off. I don't remove the pucks.
Carl makes a good point: pucks will lower your pH (and, of course, increase your CYA some). I've not worried about that in the past because our absences were relatively short, 14 days and fewer, and because I've monitored the water while using trichlor in the past I know that the pH drop isn't serious enough to require pre-planning—in my pool.
According to info learned from Richard (Chem Geek): "For every 10 ppm Free Chlorine (FC) added by Trichlor, it also increases Cyanuric Acid (CYA) by 6 ppm." I can live with those 6ppm CYA because I intentionally keep mine on the low side in anticipation of a late summer vacation.
