10 gallons will take your chlorine too high. You can do 5, though. That will take you to 12. I posted right at the same time you sent your last post. Scroll back up above yours and find mine and read it.
Hi, I didn't get a chance to get on here until now, but still at the pool maintanance of course! Okay, I didn't read where it said to take readings before bed and in the morning. I am eyeballing the situation here, and it is going wonderful! Each day it has gotten clearer and clearer, but losing chorline really fast apparently. Even still it is clearing up more and more. From green to hazy blue to cloudy to I CAN SEE THE BOTTOM DRAIN!!YEAH!!! Levels after adding at night are reading good in AM for the last two mornings, wondering if we are over the hump? When do we put stablizer in, which is then next question, I may have been pool store, whatever you call it again! I bought a thing of $32 Clor Save, it is Cyanuric acid. When I went for the 12% chorline he said I would need it next? I thought I didn't want to be needing it on Sunday with it being Father's Day. Maybe I can take back tom. when I have to go for more 12%. So what is next, changing the sand, or not?
Hold off on the stabilizer for a bit. If your water is still cloudy you aren't quite done yet. Glad it is getting clearer each day. Keep hitting it hard with FREQUENT additions of bleach. You are getting closer!
Take a look at the pictures at the following link:
http://imageevent.com/kcleavenger/poolconversion
Digger --- your other post from earlier this evening did appear. Scroll up the thread. Your post came in at 7:16 and is right there above my reply I made at 10:19!![]()
