Re: CYA/crystal clear green water
Hi Purple Girl;
(Why purple?)
Anyhow, sorry I didn't look in sooner. Green water on first fill is often iron from bacterially mediated corrosion of steel pipes or containers. I know from more experience than I care to remember that in such cases:- Iron tests will show little or no iron.
- Chelants and metal treats have little affect.
- It will EVENTUALLY dissipate with chlorine, sunshine and filtration.
- It's perfectly safe to swim in, if your chlorine level is good and your water clear.
But, I'm afraid you've been "poolstored", to use Carl's word. Phosphate removers work by precipitating phosphorous in one of two forms, one of which is hard to filter out. The other form is REALLY hard to filter out. (To be fair: the pool store staff probably doesn't know ANY of this.)
With a DE filter, it's not too bad. With a sand filter, my experience is a week plus. I've never tried to remove with an undersized Intex cartridge filter, and I'd never want to do so. My guess is that with an Intex filter it might take forever, or at least till fall.
Basically, AG pool filters come in two flavors: those that don't work very well, because they are too small, and those that work really badly because they are WAY too small. Intex pools fall into the second category.
IF you fill with clean water, and IF you never let it get cloudy, THEN it's possible to keep the water in an Intex pool clear. Otherwise, not so much.
So, it looks to me like you've got two choices.
First, you could just live with it. So long as you keep the chlorine up, and everything else OK, the iron will eventually filter or settle out. Then, you'll have a blue cloudy pool, instead of a green cloudy pool. Of course, you'll need to be careful: you'll have no warning when algae is starting, so you'll want to keep the chlorine high-ish.
Or, second, you could drain and refill. Your pool will STILL be green when you start, but you won't add the phosphate remover this time, and it will be ONLY green, instead of green and cloudy.
Do NOT waste your money on metal removers: they don't. They just help the metals stay IN the water; they do nothing to get the metals OUT of your water and pool. Besides, they often don't work with biologically sourced iron.
PoolDoc
