Re: Help!! I don't know who to believe - Chlorine Lock?
If the circulation in your pool is decent, you can initially add 10 ppm FC then wait an hour then retest and add more if the FC is very low or zero. The chlorine gets consumed very quickly at first. You may see some of it register as Combined Chlorine (CC), but it's the Free Chlorine (FC) you want to look at.
The bucket test gives you a rough minimum requirement, but your chlorine demand may still be high for some days after the chlorine at least somewhat holds. You can see this effect in the thread describing my experience of this which I summarized in this post.
