Results 11 to 18 of 18
Thread: White flakes in water
    steveinaz is offline Lifetime Member Weir Watcher steveinaz 2 stars steveinaz 2 stars
    Southern Arizona
    Default Re: White flakes in water
    Ok. Will do.
    remember to monitor your FC since you will see a small decrease in chlorine demand when you raise the CYA and most likely a larger drop in chlorine demand when you finally add the borates.
    Southern Arizona
    Well, I've got a serious case of anal-cranium disease. Checked my CYA last night, it's in the 45-50ppm range. A trip to Walmart will fix that tonight. I have re-run all my tests, I guess some of my results were out of date. I usually run all tests in the spring, and then just test Chlorine/pH throughout the swim season. I'm also going to replace a bunch of my reagents this evening.
    My pool is so easy to care for, but it's lulled me into a false sense of security. Let me get some numbers normalized, and go from there. Right now here are the numbers (tested, again, last night):
    FC=3-5ppm typically
    CC=0
    pH=7.6 but requires 1/2 cup acid every other day to maintain
    CH=710ppm
    TA=180ppm
    CYA=45-50ppm
    Salt=2600ppm (2250-2750 recommended)
    Water tmp @ testing=86 degrees
    I'll bring the CYA up to 80ppm, and I'm beating down the TA. This fall I'll do a sizable drain to lower CH. I'm also going to replace the QuikChlor SWCG with an Aqua Rite XL. In spite of the numbers, the water has looked/felt great all summer; crystal clear (minus the white flakes), though I believe it was a calcium ridden salt cell that caused that glitch.
    Southern Arizona
    An update. After 2 cleanings, my salt cell looks like new, so I got that taken care of. BTW. I tried to find PVC pieces to build a cap for my cell, making cleaning easier, and less wasteful---no luck. So I found an interesting solution...at Target they had a large cylindrical glass vase. Perfect diameter and height for cleaning my salt cell---plus, being glass I can see the cell blades through it to watch the progress. Anywho...
    FC=5ppm
    CC=0
    pH=7.5
    TA=160ppm (20ppm drop from 5 days ago)
    CH=710ppm (this will be addressed in the fall)
    CYA= (will test on Wednesday, waiting for added CYA to dissolve fully)
    I've been hammering the pool with acid, daily, and now have the CORRECT phenol red solution (R-0004). We're already noticing the clarity/quality of the water greatly improving. I'm targeting 80ppm for CYA, I'll see where we are on Wednesday.
    Thanks for the update. I was wondering about you when I made a quick sweep through the forum early this morning and your name caught my eye. Glad things are improving for you.
  6. #16
    Southern Arizona
    My posts lately look like a repeat of 3yrs ago...
    This time I'll be more patient and fix it RIGHT.
  7. #17
    That's where the POPP--pool owner patience and persistence--kicks in!! It's too bad we have to learn it the hard way, but I think we all have to go through it at some point in time!! Glad your pool problems are cleared up. And thanks for the update!!
    Southern Arizona
    Flakes are gone, go here for a continuation...http://www.poolforum.com/pf2/showthread.php?t=10034
  1. White flakes in pool
    By cscannon in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-29-2012, 11:55 PM
  2. White flakes on pool bottom
    By Beb5162 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 05-28-2012, 12:58 PM
  3. White Flakes
    By mknbob in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-02-2011, 11:20 AM
  4. White flakes in pool and spa
    By Txpoke in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-21-2011, 09:44 AM
  5. White Flakes????
    By sewzhmkr in forum Pool Chemicals & Pool Water Problems
    Last Post: 08-03-2006, 01:19 AM
