Results 1 to 10 of 34
Thread: Backwashing and shocking
    Jun 2010
    Texas, USA
    Default Re: Backwashing and shocking
    Thanks Polyvue and CarlD.
    I appreciate the input. It rained tons last night (due to hurricane Alex) so I'm in the pool to vacuum and backwash. There's lots of stuff on the bottom but nothing on the sides yet. I'll check back in when I get the FAS kit and post the new levels. Meanwhile, I'll vacuum, backwash, bleach, vacuum, backwash, bleach, .....
    Judi McRae - Katy, TX
    Doughboy Sand Dollar II 18' x 48" Vinyl liner - ~ 7,000 gal
    Pool Power Pak II pump - Media Master 1600 sand filter
    Once the fallout from Alex is over with, I would definitely shock the pool--goodness only knows what kind of crud came with the rain from the gulf!!
    Jun 2010
    Texas, USA
    I vacuumed this morning at 6:30 and put in 7 quarts of bleach. By 4:00 pm, the pool was full and I could see a layer of brown on the bottom. It's almost 7:00 pm, I've had to let more water out of the pool (so much for the bleach!), and it's still raining cats and dogs. I'm setting the alarm for 3:00 am ... thanks so much for all your encouragement everyone!
    Jun 2010
    Texas, USA
    Hey, I'm back!
    My pool hasn't beat me yet. Hurricane Alex almost did! We had constant rain in Katy... 26 miles west of Houston ... for two days. Needless to say, lilly-livered coward that I am, I did not venture into the pool for any length of time. I took advantage of breaks in the rain to vacuum when I could and every time I vacuumed I backwashed to waste (Alex was doing just great in replacing the water!) and I dumped a gallon of bleach morning and night.
    Every time I looked at the pool after dumping the bleach, I had a visible layer of algae... but it decreased with each application. Yesterday evening I vacuumed just before sunset, poured another gallon of bleach and lo and behold, this morning I had negligible algae!!! I vacummed, dumped another gallon of bleach and raced to WalMart to get some distilled water. I did the 3-1 (OTO) ratio for the Chlorine: FC/15; TC/15; I did the regular DPD test for the rest: AK/140; pH/8.2; CYA/55.
    The water is beautifully clear.
    Did I do good?
    Yep. You done good! Tonight, test the cl at sundown and then early tomorrow morning and see if you lose more than 1ppm. If you do, shock it back up. Continue keeping high cl until you can hold it overnight. Also, retest your pH whenever your cl isn't high so you can get an accurate reading.
    Jun 2010
    Texas, USA
    Will do.
    Thanks to all for your wonderful assistance!
