Re: Help with getting levels right please!
one4irish
We are back and do not have a green pool! We have skimmed and vac pool, tested water, changed filter and now the pump is running. I did order the test kit Watermom suggested but it is not here yet, so I used my hth tester and here are my results:
PH 7.5
CL/BR 5/10
TA 190
TH 300
I know my TA is alittle high. Right now the water looks alittle cloudy but might just need the pump to run to clear that up. I do have some PH minus, which is what they say to use to bring it down, but will that bring my ph down too low?
You can utilize the Pool Calculator to determine how much pH minus (dry acid) to add but if you want to reduce pH do it a little at a time so you don't overshoot the mark. If the purpose is to reduce TA, muriatic acid (MA) might be a better choice -- the only choice you should consider if you have a Salt Water Chlorine Generator (SWG). Where the step-by-step reducing TA stickie suggests the PS233 test kit, you can substitute the Total Alkalinity test found in the Taylor K-2006.
If the CYA level is indeed about 30 PPM, your report of a [Free] Chlorine level of 5 PPM is right on the money. Of course, if the method you're using reports a maximum level of 5 PPM Total Chlorine, it's possible that it's a lot higher -- and that the cloudiness you report might show up in CCs. You'll be able to confirm all of this when you get your Taylor kit
16'x29' free-form 14K gal IG gunite pool; SWCG & sodium hypochlorite 8.25%; Hayward SwimClear C4025 cartridge filter; Hayward SP3202VSP TriStar Variable Speed Pool Pump; custom test kit based on Taylor K-2006C; city; PF:8.6
