Well, I wasn't gonna mention it .............![]()
That is what is great about this place --- we got each other's backs!
Watermom-- Yes we have been "pool-stored," but the Taylor K-2006 kit was ordered last night so hopefully we're headed in the right direction now. After reading your post and waterbear's post, we have learned more in a day than we have in a month!! So, thank you.
Waterbearer--Yes, the test kit was the Wal-Mart HTH kit.
So today, I'm going to get diluted water to do the shot glass test and add borax to the skimmer. (My last trip to Wal-Mart I didn't see any, so hopefully I can find a place that has some.) Should I do the shot-glass test before I add the borax or should I test the chlorine and pH levels tomorrow after adding the borax?
Just an FYI if anyone is having trouble finding borax, the company's website has a store locator within a radius of your zipcode (sorry if someone else already posted this). For the brand select laundry care: http://www.henkelna.com/henkel-store-locator-9949.htm
Whether you do the chlorine test before or after the Borax doesn't matter, the Borax won't interfere with it. I would wait until after the Borax has been in for a couple of hours before retesting pH, but keep in mind that if the Chlorine is still higher than 10 ppm you're still likely to get a falsely high pH reading.....
Glad we can help. I have found that borax is often sold out and does not come in for several weeks so I pick up a box or two to keep on hand when I see it. (We use it for LOTS of things around the house. It truly is a miracle product!)
BTW, the name is waterbear, not waterbearer!Google it!
Waterbear--my apologies...I must have read waterbearer in my haste
So yesterday around 6pm I added a half box of borax. I can already see further down past the ladder than I did yesterday. About 5 minutes ago I tested pH and chlorine:
With the shot glass method I had to do 2 shots of distilled water and 1 shot pool water. With that I got 5...making it 15
For pH it looks to be about 7-7.2
Also, how much water loss/evaporation should I be experiencing each day? From yesterday to today we lost about an inch. Yesterday was about 90 degrees. We’ve been in the upper 90s-100 all week. So is this normal?
You're going to want to add more Borax to get the pH up some more...
What part of the country are you in? Water loss in normal, but I'm not sure about a full inch in 24 hrs, I'm sure others will chime and and give you a sense as to if that's normal or not. I only loose an inch a month due mainly to splash out as my pool is covered when it's not in use.
Evan S.
AG FastLane Pool, 9x13 ~ 3,000 gal, COVERED/INSULATED 23X7, 30 gpm water pump (runs 12 hrs a day) AND a Hayward Power-Flo LX 1.5 hp Pump (only used on occasion for the pool sweep), Hayward 100K BTU Heater, Waterway Flo-Pro Skim Filter & Slime Bag, no other filters
